iPhone 16 Pro Max Battery Removal
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. iPhone 16 Pro Max Battery Removal, Battery adhesive information: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Your iPhone's battery is secured with three stretch release adhesive strips. The next four steps show how to remove them and free your battery.
    • Be careful not to dent or puncture the battery. Avoid using sharp tools near it.
  2. iPhone 16 Pro Max Battery Removal, Remove the battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 16 Pro Max Battery Removal, Remove the battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 16 Pro Max Battery Removal, Remove the battery: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tip of an opening pick to separate a black pull tab from the bottom of the battery.
    • Use tweezers to help peel the tab away from the battery.
    • Don't try to pull the tab out from under the battery just yet.
  3. iPhone 16 Pro Max Battery Removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 16 Pro Max Battery Removal: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 16 Pro Max Battery Removal: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers or your fingers to grab the pull tab.
    • Slowly pull the adhesive out from under the battery at as low of an angle as possible.
    • Give the strip plenty of time to stretch and re-grip it as necessary. Avoid dragging it over the components or cables above the battery.
    • When the strip becomes too long, wrap it around your tweezers and continue pulling.
    • If a strip breaks off, try to retrieve it from under the battery. If you can't retrieve it, move onto the next strip.
  4. iPhone 16 Pro Max Battery Removal: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 16 Pro Max Battery Removal: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the procedure with the two remaining adhesive strips.
    • Carefully bend the lower assembly cable out of the way as needed to access the adhesive strips.
  5. iPhone 16 Pro Max Battery Removal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you removed all three stretch release adhesive strips, congratulations! Remove the battery and skip down three steps for reassembly instructions.
    • If one or more adhesive strips broke, skip to the next step to remove them with isopropyl alcohol.
  6. iPhone 16 Pro Max Battery Removal, Alternate method to remove the battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The next two steps show how to remove the battery if the adhesive strips broke.
    • Lift the bottom edge of the frame to tilt the iPhone.
    • Use a pipette or a syringe to apply 2–3 drops of high concentration (>90%) isopropyl alcohol along the bottom edge of the battery, close to where each broken adhesive strip came out.
    • Wait one minute for the isopropyl alcohol to flow under the battery and soften the adhesive.
  7. iPhone 16 Pro Max Battery Removal: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 16 Pro Max Battery Removal: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat edge of an opening pick between the left edge of the battery and the frame.
    • Pry the battery upwards slowly with steady force. Give the adhesive time to release.
    • Don't bend or crease the battery. If it feels stubborn, apply a few more drops of isopropyl alcohol and try again.
    • Once the adhesive loosens, grab and remove the battery.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
297,732 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,677crwdne2935297:0
crwdns2942667:0crwdne2942667:0 140
