Remove the four screws securing the upper connector cover:
Two 1.4 mm-long Phillips screws
One 3.5 mm-long Phillips screw
One 1.0 mm-long tri-point Y000 screw
Use tweezers or your fingers to remove the upper connector cover.
Use the point of a spudger to disconnect the power/Camera Control button press connector.
Disconnect the two rear camera press connectors, located underneath and to the left of the power/Camera Control button connector.
Use your Phillips screwdriver to remove the three screws securing the rear cameras:
One 3.2 mm‑long screw
One 4.7 mm‑long screw
One 2.4 mm‑long screw
Use a spudger or clean fingertip to pry up the top edge of the rear cameras until you can grab them with your fingers.
Lift the cameras straight up, then pull them towards the top of the phone to remove them.
