If you're curious about all the chips in the new iPhone 14 Pro Max, you've come to the right place.
These board shots are taken using a US iPhone 14 Pro Max—model number A2651. This model lacks a physical SIM tray, but contains hardware to support 5G mmWave bands, as well as satellite communication.
Check out our iPhone 14 Pro Max teardown for more details.
Special thanks to our community member Chunglin Chin for contributing to this!
crwdns2936621:0crwdne2936621:0
Chip ID part 1:
SanDisk SDMVGKLK2 128G 128 GB NAND flash memory
Apple/Dialog Semiconductor 338S00819-A1 power management
Likely Apple/Cirrus Logic 338S00843 voice processor
Apple/Cirrus Logic 338S00537 audio amplifier
Likely Apple/Dialog Semiconductor 338S0081C ? power management
Texas Instruments TPS61280H DC-DC converter
Maybe STMicroelectronics EEPROM
Chip ID part 2:
Possibly Infineon load switch
NXP Semiconductor NTB0101GS1 1-bit translating transceiver
Texas Instruments LSF0101 1-bit bidirectional voltage level translator
Chip ID part 3:
WiFi/Bluetooth Module (possibly)
Chip ID part 1:
Apple APL1W10/339S01104 A16 64-bit hexa-core applications processor w/ penta-core GPU layered underneath most likely Samsung K3LK2K20CM-EGCP 6 GB LPDDR5 SDRAM memory
Apple APL109A/338S00942 power management
Apple/Dialog Semiconductor 338S00839-B0 power management
Broadcom BCM59365EA1IUBG wireless power receiver
STMicroelectronics STB601A05 power management
Texas Instruments TPS65657B0 display power supply
BCM59365EA1IUBG It's lab controller, not wireless
Ok, WTH happened at the lower left corner of the power management chip? Being a bit overzealous with the heat to open the case? Several components are shifted.
Chip ID part 2:
Texas Instruments LM3567A1 LED flash driver
Apple/Cirrus Logic 338S00738 audio codec
Likely Analog Devices taptic engine driver
Texas Instruments CD3710A1 VCSEL array driver
NXP Semiconductor CBTL1618A0 DisplayPort multiplexer
Texas Instruments USB 2.0 dual repeater
onsemi DC-DC converter
Chip ID part 3:
Likely onsemi DC-DC converter
Possibly STMicroelectronics serial EEPROM memory
Chip ID part 4:
Likely USI UWB module
Broadcom AFEM-8245 front-end module
Chip ID part 2:
NXP Semiconductor SN210V NFC controller w/ secure element
Satellite module (possibly)
Qualcomm SDX65M X65 5G modem
Qualcomm SDR735 RF transceiver
Qualcomm SMR546 RF transceiver
Broadcom AFEM-8231 front-end module
Skyworks SKY58290-20 front-end module
Qulacomm SMR546 RF should be at left side, this is a mistake.
Chip ID part 3:
Broadcom AFEM-8240 front-end module
Likely Skyworks SKY58853-17 ? front-end module
Possibly Skyworks SKY52628 antenna switch module
Possibly Skyworks SKY5xx92-16 power amplifier module
Chip ID part 4 - sensors:
Bosch Sensortec 6-axis accelerometer/gyroscope
Beside BOSCH's 6轴加速计/陀螺仪 sensor, there is no Magnetic sensor ? or it's still using Alps HSCDTD00xA as ecompass? Thanks!
Antennas:
Connector to possibly the satellite antenna
5G mmWave patch antenna
crwdns2947412:015crwdne2947412:0
Are the 14 Pro/Max using TLC or QLC NAND?
Nobody idea?
boris_dg -
Possibly TLC, but so far I know, the NADA on pro and pro max at least from 3 suppliers. Hope no QLC
Do all models have the satellite hardware or only the US model? Would be a shame if they can't add more countries for the SOS feature because the hardware is missing.
Which chip is responsible for the new dual frequency GPS? Is there an additional GPS antenna for L5 band? Improved GPS in all models? Because sadly I see absolutely no GPS accuracy improvement in Switzerland with 14 Pro Max compared to 13 Pro Max (using iOS 16.0.1).
So many questions. Hope they can be answered. Tnx for your great work iFixit team!
Qualcomm SDR735 RF transceiver might include GPS(GNSS) L1+L5 support.
洪小福 -
who made the 5G mmWave antena
Probably Murata or USI vendor
洪小福 -
Is iPhone14/plus also have X65 modem?
Probably the old X60.
boris_dg -
If based on X60. how to connect with satellites?
I don't think that particular chip has something to do with Satelite.
boris_dg -
But in iphone14 teardown article, ifixit said: "we can confirm that the satellite connectivity is powered by a new Qualcomm X65 modem, which adds new 2.4 GHz n53 band capabilities to support Globalstar."
So if the modem is carrying this functionality, than should be X65.
boris_dg -
Yes, Qualcomm SDX65M is on board, very clearly.
how to switch motherboard 14 pro to 14 pro max?
Since when has SanDisk been producing NAND flash memories for iPhones?
Atti - crwdns2934203:0crwdne2934203:0
