iPhone 13 WiFi Chip Replacement
crwdns2936621:0crwdne2936621:0
iPhone WiFi Chip Repair Solution
  1. iPhone 13 WiFi Chip Replacement, Disassemble the iPhone 13: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 13 WiFi Chip Replacement, Disassemble the iPhone 13: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 13 WiFi Chip Replacement, Disassemble the iPhone 13: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Cover the cameras with protection stickers.
    • Remove the motherboard and split it.
  2. iPhone 13 WiFi Chip Replacement, Test the Wi-Fi Circuits: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 13 WiFi Chip Replacement, Test the Wi-Fi Circuits: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Test the circuits related to the Wi-Fi module to verify that they are normal.
  3. iPhone 13 WiFi Chip Replacement, Remove the NAND Chip: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 13 WiFi Chip Replacement, Remove the NAND Chip: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 13 WiFi Chip Replacement, Remove the NAND Chip: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • It is not possible to read the Wi-Fi serial number (SN) simply by connecting the iPhone to the programming software. Therefore, we will remove the NAND chip.
    • Heat the NAND chip evenly with a hot air gun at 420°C and airflow 80.
    • Pry the NAND chip up.
    • Apply some flux to the soldering pad of the NAND chip.
    • Remove the tins from the soldering pad using braid and a soldering iron.
  4. iPhone 13 WiFi Chip Replacement, Use the Luban Programmer: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 13 WiFi Chip Replacement, Use the Luban Programmer: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 13 WiFi Chip Replacement, Use the Luban Programmer: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the NAND chip in a Luban programmer.
    • Connect the programmer to a PC and open the programming software.
    • Click "Check Factory Data" to read the EcID of the iPhone.
    • Read the EcID from the NAND chip.
  5. iPhone 13 WiFi Chip Replacement, Write New Wi-Fi SN Data: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 13 WiFi Chip Replacement, Write New Wi-Fi SN Data: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 13 WiFi Chip Replacement, Write New Wi-Fi SN Data: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place a new Wi-Fi module into the Luban programmer to write in the Wi-Fi SN.
    • Copy the EcID and select WiFi Operations on the navigation menu.
    • Paste the EcID and click "Check now."
    • Then click "Write now."
    • The Wi-Fi SN has been written into the new Wi-Fi module.
  6. iPhone 13 WiFi Chip Replacement, Replace the Wi-Fi Module: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 13 WiFi Chip Replacement, Replace the Wi-Fi Module: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 13 WiFi Chip Replacement, Replace the Wi-Fi Module: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the signal board onto a fixture.
    • Cover some other components with Kapton tape for protection.
    • Heat the Wi-Fi module with a hot air gun and use a pry knife to remove the edge adhesives.
    • Pry up the Wi-Fi module.
    • Apply some flux to the soldering pad of the Wi-Fi module.
  7. iPhone 13 WiFi Chip Replacement, Solder the New Wi-Fi Module: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 13 WiFi Chip Replacement, Solder the New Wi-Fi Module: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 13 WiFi Chip Replacement, Solder the New Wi-Fi Module: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the tins from the soldering joints of the signal board.
    • Remove the tins from the soldering joints of the logic board.
    • Align the new Wi-Fi module carrying the SN to the soldering pad.
    • Solder the new Wi-Fi module with a hot air gun at 380°C and airflow 60.
  8. iPhone 13 WiFi Chip Replacement, Solder the NAND Chip: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Solder the NAND chip with a hot air gun at 380°C and airflow 60.
  9. iPhone 13 WiFi Chip Replacement, Testing: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 13 WiFi Chip Replacement, Testing: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 13 WiFi Chip Replacement, Testing: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Put the logic board and the signal board into a motherboard-layered test fixture.
    • Connect the iPhone 13 screen cable and the power cable.
    • Use a pair of tweezers to trigger the power-on.
    • The iPhone 13 should power on properly.
    • Go to settings to check if the Wi-Fi function toggle is resumed.
  10. iPhone 13 WiFi Chip Replacement, Reassemble and Done: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 13 WiFi Chip Replacement, Reassemble and Done: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 13 WiFi Chip Replacement, Reassemble and Done: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Solder the signal board with the logic board.
    • Assemble the iPhone 13 and test the Wi-Fi function.
    • Test and Wi-Fi should be restored and connected properly.
REWA
crwdns2935283:011/24/20crwdne2935283:0
17.261 crwdns2915208:0crwdne2915208:0
crwdns2935297:055crwdne2935297:0
crwdns2936753:07crwdne2936753:0 67
crwdns2936753:030crwdne2936753:0 322
crwdns2942667:0crwdne2942667:0 1,018
