crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0iPhone 13 Procrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. iPhone 13 Pro Full Chip ID, iPhone 13 Pro Full Chip ID: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Logic board, side 1:
    • Apple APL1W07 A15 Bionic SoC layered with what's most likely 6 GB of SK Hynix LPDDR4X SDRAM
    • Apple APL1098 power management IC
    • Apple 338S00762-A1 power management IC
    • STMicroelectronics STB601A05 power management IC
    • Apple 338S00770-B0 power management IC
    • Texas Instruments TPS65657B0 display power management IC
    • NXP Semiconductor CBTL1616A0 display port multiplexer
    The light blue rectangle is what we would call the charging ic. It is a variant of the earlier Tigris and later Yangtze chips that are commonly damaged by rogue chargers. The function of this chip is to create the main power rail from the battery or charger voltage, and control charging of the battery while on the charger. Due to the lack of public schematics for iPhone 13 series, we'd like to propose calling this chip "Genesee" following the river naming convention. The Genesee river is in Rochester, NY
    jessabethany - crwdns2934203:0crwdne2934203:0
    The purple chip is a new generation of the usb port communication hub. In earlier models this is the famous tristar chip, later called hydra in the iPhone 8 and then Kraken in iPhone 11.
  2. iPhone 13 Pro Full Chip ID: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Logic board, side 1 (cont.):
    • Texas Instruments CD3710A1 VCSEL array driver
    • Texas Instruments USB 2.0 dual repeater
    • ON Semiconductor DC-DC converter
    • Possibly a NXP Semiconductor power management IC
    • Possibly a NXP Semiconductor load switch
  3. iPhone 13 Pro Full Chip ID: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apple/USI U1 ultra-wideband chip
    • Skyworks SKY58271-19 front-end module
    • Skyworks SKY58276-17 front-end module
    • Likely a Broadcom AFEM-8225 front-end module
    • Likely a Skyworks SKY59723 power amplifier module
    • Likely a Murata 141 RF switch module
    • Likely Broadcom filters
  4. iPhone 13 Pro Full Chip ID: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Alps HSCDTD00xA electronic compass
  5. iPhone 13 Pro Full Chip ID: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Logic board, sides 2 and 3:
    • 128 GB of Kioxia NAND flash memory
    • STMicroelectronics ST33Jxxx secure microcontroller w/ eSIM
    • Possibly an Apple/Cirrus Logic 338S00817 audio processor
    • Apple/Cirrus Logic 338S00739 audio codec
    • Apple/Cirrus Logic 338S00537 audio amplifier
    • Broadcom BCM59365 wireless power receiver
    • Likely an Analog Devices haptic driver
  6. iPhone 13 Pro Full Chip ID: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Logic board, sides 2 and 3 (cont.):
    • Qualcomm PMX60 power management IC
    • Apple 338S00616 power management IC
    • Texas Instruments LM3567A1 LED flash driver
    • Likely a STMicroelectronics DC-DC converter
    • Nexperia 74AVC1T45 3-state voltage level translator/transceiver
    • Nexperia LSF0101 1-bit bidirectional voltage level translator
  7. iPhone 13 Pro Full Chip ID: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • USI 339S00761 WiFi/Bluetooth module
    • Qualcomm SDX60M 5G modem
    • Possibly a Qualcomm SDR868 5G RF transceiver
    • Broadcom AFEM-8215 front-end module
    • Possibly a Skyworks SKY53838-17 front-end module
    • NXP Semiconductor SN210V NFC controller with secure element
    • Likely a Skyworks SKY57217 power amplifier module
  8. iPhone 13 Pro Full Chip ID: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Qualcomm QET510 envelope tracker
    • Qualcomm QET5100 envelope tracker
    • Likely a Qorvo envelope tracker
    • Likely a Skyworks SKY514xx RF switch module
    • Likely Skyworks RF switch
    • Likely Murata antenna switch module
    • Antenna tuning switch
  9. iPhone 13 Pro Full Chip ID: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Bosch Sensortec 6-axis accelerometer/gyroscope
    Is there a lable for where each socket connects to?
    lunacyworks - crwdns2934203:0crwdne2934203:0
Craig Lloyd
crwdns2935283:002/10/16crwdne2935283:0
39,588 crwdns2915208:0crwdne2915208:0
crwdns2935297:082crwdne2935297:0
crwdns2947412:08crwdne2947412:0
Which one is the wifi/bt chip?
u2f u2f - crwdns2934203:0crwdne2934203:0
Refer to Step 7,
There is no WiFi/BT chip on the main board. Instead, Apple uses USI 339S00761 WiFi/Bluetooth module .
JJ Wu -
Is barometer still Bosch’s solution?
JJ Wu - crwdns2934203:0crwdne2934203:0
Does anyone know anything more about the USI 339S00761 WiFi/Bluetooth module? Specifically, it would be really interesting to understand if there is Bluetooth LE Audio capabilities hidden there.
Gustaf Rosell - crwdns2934203:0crwdne2934203:0
please i need a help my iphone 13 pro i try to restore and gave me error unable to restore idevice (-1)
izeko mobile - crwdns2934203:0crwdne2934203:0
How do the two halves of the logic board “clamshell” communicate with each other? Do the solder pads on the perimeter of each board act as vias? Incredibly impressive construction.
George - crwdns2934203:0crwdne2934203:0
do you have a schematic diagram of data connector flex for iPhone 13 PRM model... thank you in advnce
leo del monte - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 15
crwdns2936753:07crwdne2936753:0 135
crwdns2936753:030crwdne2936753:0 733
crwdns2942667:0crwdne2942667:0 56,326
