crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0iPhone 12crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. iPhone 12  Teardown, Remove the SIM: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12  Teardown, Remove the SIM: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the SIM Card tray using a SIM Card eject tool
  2. iPhone 12  Teardown, Unscrew the lower screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 12  Teardown, Unscrew the lower screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 12  Teardown, Unscrew the lower screws: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn off the device
    • Unscrew the two 6.9 mm long Pentalobe screws.
  3. iPhone 12  Teardown, Raise the display: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 12  Teardown, Raise the display: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 12  Teardown, Raise the display: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a heated iOpener all around the edge of the screen to loosen the adhesive under the display.
    • Lift the display with a suction cup and insert a thin object to separate the screen from the frame.
    • Slide the fine object along the entire edge to cut the adhesive.
    • Raise the display.
  4. iPhone 12  Teardown, Disconnect the display: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 12  Teardown, Disconnect the display: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 12  Teardown, Disconnect the display: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 6 Phillips # 00 screws.
    • With a spudger or with your fingernails, lift the two connectors.
    • Lift the connector underneath.
    • Disconnect the display connector.
  5. iPhone 12  Teardown, Remove the rear camera: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 12  Teardown, Remove the rear camera: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 12  Teardown, Remove the rear camera: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the 4 Phillips # 00 screws.
    • With a spudger or fingernails disconnect the two rear camera connectors.
    • Remove the rear camera.
  6. iPhone 12  Teardown, Remove the front camera.: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12  Teardown, Remove the front camera.: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With a spudger or fingernails to disconnect the three connectors that connect the front camera.
    • Remove the front camera.
  7. iPhone 12  Teardown, Remove the battery holder: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12  Teardown, Remove the battery holder: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With a spudger or fingernails disconnect the battery holder connector.
    • Unscrew the 3 Phillips # 00 screws.
    • Remove the battery holder.
  8. iPhone 12  Teardown, Remove the camera flash: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With a spudger or fingernails disconnect the rear camera flash connector.
    • Unscrew the 2 Phillips # 00 screws.
    • Remove the rear camera flash.
  9. iPhone 12  Teardown, Remove the SIM card holder: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 12  Teardown, Remove the SIM card holder: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 12  Teardown, Remove the SIM card holder: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the 2 screw holders with the suitable screwdriver.
    • With a spudger or fingernails to disconnect the SIM card holder connector.
    • Remove the SIM card holder.
  10. iPhone 12  Teardown, Remove the battery logic board: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12  Teardown, Remove the battery logic board: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 2 Phillips # 00 screws.
    • With a spudger or fingernails disconnect the 3 battery connectors.
    • Unscrew the screw holder with a standoff screwdriver for iphone.
    • Remove the film with a spudger.
    • Attention this last step is necessary to remove the logic board.
    • Remove the logic board.
  11. iPhone 12  Teardown, Remove the speaker: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12  Teardown, Remove the speaker: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the 5 Phillips # 00 screws.
    • Remove the speaker.
  12. iPhone 12  Teardown, Remove the taptic engine: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12  Teardown, Remove the taptic engine: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 2 screw holders with a standoff screwdriver for iphone
    • Remove the taptic engine connector with a spudger or fingernail.
    • Remove the taptic engine.
  13. iPhone 12  Teardown, Remove the battery: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12  Teardown, Remove the battery: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the adhesive under the battery.
    • To remove the adhesive under the battery, remove the stickers marked in red in the first photo.
    • Remove the battery.
  14. iPhone 12  Teardown, Remove the charging port: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 12  Teardown, Remove the charging port: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew 6 Phillips # 00 screws.
    • Remove the 4 screw holders with an iPhone standoff screwdriver.
    • Attention, the previous step is essential to remove the charging port.
    • Remove the charging port.
    • Be careful not to make too strong, this could damage some components.
  15. iPhone 12  Teardown: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • And here are all the components that make up the new iPhone 12.
crwdns2934873:0crwdne2934873:0
it en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Andrea Alfani
crwdns2935283:004/20/22crwdne2935283:0
8,488 crwdns2915208:0crwdne2915208:0
SussyFixers crwdns2935289:0SussyFixerscrwdne2935289:0
Community
crwdns2947412:07crwdne2947412:0
I had problem with nfc. When it was changed. Have any solution?
Ak H - crwdns2934203:0crwdne2934203:0
I don't see any mentioning of the microphone, Is the Microphone an integral part of the charging port harnes?
Paal Halvorsen - crwdns2934203:0crwdne2934203:0
This guide is missing A LOT of steps
Jason Oestrike​ - crwdns2934203:0crwdne2934203:0
This is definitely not a US iPhone 12! e careful as the antenna can tear easily and potentially ruin a motherboard.
Kyle Morrell - crwdns2934203:0crwdne2934203:0
>disconnect battery connector
>disconnetct 3 battery connectors
wtf?)) why do you call any FPC "battery connector"? so NPC
Джокер Богданофф - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 51
crwdns2936753:07crwdne2936753:0 349
crwdns2936753:030crwdne2936753:0 1,993
crwdns2942667:0crwdne2942667:0 64,533
