Use this guide to replace any clips broken during removal of the display assembly.
            If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
            Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
            Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
            There are 14 metal clips holding the display assembly in place, shown at left. As you pry in the following steps, do your best to pry around these clips and not slice through them with your opening tool.
 A clearer explanation of the orientation is needed here. The bar code is at the top left of the iPad when you are looking at the screen.
            Insert a metal spudger between the top edge of the display assembly and the rear panel assembly.
            Rotate the spudger away from you to release the tabs along the top edge of the display.
            Insert a second metal spudger between the top edge of the display assembly and the rear panel assembly to keep the tabs from snapping back into place.
 Tip* "ONLY WITH METAL SPUDGER* heat it with a lighter till its warm to touch, then slide it like a butter knife. it reduces chances of chipping glass. I've found that by using a thicker iPad tool dents the back less(not at all if your careful) and start prying just under the volume button and working my way down works better as the metal clips are on all sider except the right side. It would be really helpful to point out where all the clips and tabs are, and to show a picture of them (unbroken), so you know what you're trying to release.
            With one spudger, work your way along the right edge of the iPad.
            The front panel is held to the aluminum back by metal clips on the top, bottom, and left sides. The right side has plastic tabs which slide into recesses in the backplate.
            Once the clips are released, lift the left side of the front panel up and slide it to the left to clear the tabs from the aluminum backplate.
 Its seems easier to undo the clips on the left and bottom by levering them with an iPad tool and pusing the clips in from the edge with another tool when i can visually see them. One the right side, bottom and most of the left side is done there isnt much need to do the top as it will slide off if moved about a centimeter
            Lift the display assembly away from the rear panel assembly by its bottom edge.
            In the following steps, you will disconnect the three cables attaching the display assembly to the logic board. The cables are for the following components:
            Digitizer
            Ambient Light Sensor
            Display Data Cable
 It would be easier to detach the Display Data Cable at its connector on the far right in the picture, since there doesnt seem to be much play to undo the suggested one.
            Use the edge of a plastic opening tool to flip up the retaining flaps holding the digitizer ribbon cables in their sockets on the logic board.
            Pull the digitizer ribbon cables straight out of their sockets.
 Adding this comment in its proper place: After flipping up the metal retainer, pull it sideways. Do not pull it up vertically.
            Use a plastic opening tool to remove the ambient light sensor connector from its socket by gently prying upward.
            Disconnect the display data cable from the main board by flipping up the metal retainer by its black plastic pull tab.
            Pull the cable connector away from its socket.
 IMHO, unhooking data display cable from the other end is preferable to the above location, since the cable itself is sealed or taped onto the assembly.
            Remove the display assembly from the rear panel assembly.
            To replace a broken clip, first remove the T5 Torx screw securing the broken base of the clip to the display assembly.
            Place a new clip on the positioning pins molded into the display frame, and reinstall the T5 Torx screw to secure the two pieces together.
crwdns2935229:021crwdne2935229:0
I'm fixing an ipad wifi for a friend and he managed to break the clips around the digitizer panel. These are held in place with hexalobe screws and some have EMI tape on them... Does anyone know where I could find replacement mounting clips?
1) Are you recommending to cover the display with clear packing tape even if it is intact (not cracked)?
2) If so,will the tape take the display’s oleophobic coating with it when removed?
Mitch Stary - crwdns2934203:0crwdne2934203:0
Hola necesito comprar
Alsone Michel - crwdns2934203:0crwdne2934203:0
Hola, ¿no estoy seguro si te refieres a las gafas de protección o a la pantalla? Te dejo los dos enlaces aquí:
iPad LCD Panel
crwdns2937315:0IF145-125crwdne2937315:0
Sandra Hiller -
