Follow the steps in this guide to replace the screen in an iPad Pro 12.9", or to access other internal components for servicing.
Note that the home button installed in your original screen is paired to the iPad's logic board, and will need to be removed and transferred to the new screen to retain Touch ID functionality.
Before beginning, check to see if your replacement part has a daughterboard adhered to its back. If so, this guide will work for you. Otherwise, you will need to transfer the board from the old screen to the new one. Transferring the daughterboard from the original to replacement unit will require specialty microsoldering equipment and we recommend DIY users source a new part rather than attempt the procedure.
Parts of this guide were shot with a Wi-Fi model and as such the internals may look slightly different from the LTE model. The procedure is the same for both models except where noted.
The opening procedure for this iPad Pro is shown using a Halberd Spudger. If you don’t have one, you can use an opening pick instead—the process is the same.
Completely power down your iPad before you begin.
If your screen is cracked, lay overlapping strips of clear packing tape over the iPad's screen until the whole face is covered.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
As you slice through the adhesive, note the following:
The top has a large patch of thick adhesive. You'll need to slice 1/2" deep in order to cut the adhesive.
Don't slice deeper than 2 mm along the long edges of the iPad, or you risk damaging the display panel.
The lower edge also has thick patches of adhesive, but there are delicate flex cables in each corner. Don't slice deeper than 1/4" around the lower corners.
Heat an iOpener and lay it over the left edge of the iPad to soften the adhesive holding the screen in place.
Wait two minutes for the adhesive to soften before proceeding to the next step. The edge should be slightly too hot to the touch.
crwdns2935267:0crwdne2935267:0Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Place an object under your iPad so it rests level between the suction cups.
Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
Pull the blue handle forward to lock the arms.
Turn the handle clockwise 360 degrees or until the cups start to stretch.
Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
Wait one minute to give the adhesive a chance to release and present an opening gap.
If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
Skip the next two steps.
Attach a suction cup to the left edge of the iPad's screen, above the Smart Connector port.
While holding down the corners of the iPad, repeatedly pull up on the screen, then ease it back down to weaken the adhesive. This will eventually create a small gap in the seam.
Once you've created a small gap, insert the tip of an opening pick into the gap.
Lay a hot iOpener along the bottom left corner of the iPad, spanning from the opening pick to the home button.
After letting the adhesive soften, insert an opening pick or halberd spudger into the gap next to the Smart Connector.
Use an opening pick or halberd spudger to slice the adhesive along the bottom left side of the iPad. If the slicing becomes difficult, reheat the edge and try again.
Insert a pick in the bottom left corner of the iPad to prevent the adhesive from resealing.
Lay a hot iOpener along the upper left corner of the iPad, spanning from the opening pick to the front-facing camera. Wait a minute to let the adhesive soften.
Use an opening pick to slice the adhesive along the upper left side of the iPad. If the slicing becomes difficult, reheat the edge and try again.
Insert a pick in the upper left corner of the iPad to prevent the adhesive from resealing.
Reheat your iOpener and lay it over the top edge of the device. Wait a couple minutes for the adhesive to soften.
Use an opening pick to slice through the top edge of the iPad, stopping before you reach the front-facing camera.
If the slicing becomes hard, reheat the edge and try again.
Insert an opening pick just before the front-facing camera to keep the adhesive from resealing.
Insert an opening pick or a halberd spudger blade just past the front-facing camera.
Use the opening pick to slice through the adhesive in the upper right corner.
Insert an opening pick in the upper right corner to prevent the adhesive from resealing.
Soften the adhesive by heating the right edge of the iPad using an iOpener.
Use an opening pick or halberd spudger to slice along the right edge of the iPad, till you reach the lower right corner.
Leave an opening pick in the middle of the right edge to prevent the adhesive from resealing.
Leave an opening pick in the lower right corner of the iPad to prevent the adhesive from resealing.
Use an iOpener to heat the lower edge of the iPad.
Insert an opening pick or a halberd spudger blade 1/4" into the lower right corner of the iPad.
Slide the opening pick along the lower edge of the iPad, stopping short about 1/2" before reaching the home button.
Slide the tip of an opening pick or a halberd spudger to cut the adhesive below the home button.
After you slice below the home button, reinsert the tip of an opening pick or a halberd spudger blade 1/4" into the lower edge.
Slice along the lower edge until you reach the opening pick.
At this point, you've sliced through most of the screen adhesive. Use an opening pick to carefully slice any remaining adhesive along the edges until the screen is freed. If some parts are stubborn, heat the area with an iOpener to loosen the adhesive.
Lift up the upper edge of the screen and slide the entire screen towards the front-facing camera to access the iPad's internal components.
Use masking tape to tape the lower edge of the screen to the frame to prevent the screen from slipping.
Attach a long strip of masking tape to the top edge of the screen. Fold the tape over the edge and make sure that the tape is attached securely.
Attach the other end of the strip to the bottom edge of the iPad frame to hold the screen at an angle. Make sure the tape attaches securely to the frame.
Use a Phillips screwdriver to remove the nine screws securing the logic board EMI shield:
Eight 1.2 mm screws
One 2.4 mm screw
Lift the logic board EMI shield from the edge nearest the top of the iPad.
Peel up and remove the EMI shield from the logic board.
Remove the logic board EMI shield.
Use a Phillips screwdriver to remove the 1.8 mm screw securing the battery connector.
Make a battery blocker using a playing card and slide it underneath the logic board connector to disconnect the battery.
Leave the blocker there to prevent the battery connector leads from making contact until you have completed your repairs.
Use a Phillips screwdriver to remove the three screws securing the display cable bracket:
Two 2.4 mm screws
One 1.2 mm screw
Remove the display cable bracket.
Use the flat end of a spudger to pry up and disconnect the display and digitizer cables from their logic board sockets.
Remove the screen.
If your screen didn't come with pre-applied adhesives, use our screen adhesive application guide to install fresh pre-cut adhesive strips when reassembling your iPad.
Use tweezers to remove the tape covering the ZIF connector above the home button.
Use the point of a spudger to lift the flap on the ZIF connector that secures the cable.
Use tweezers to slide the cable out of the ZIF connector.
Use an iOpener, heat gun, or hair dryer to soften the adhesive under the cable before you pry it up.
Alternatively, apply a few drops of isopropyl alcohol to the cable and wait for a minute to let the adhesive soften.
Starting from the ZIF connector, use an opening pick to separate the home button cable from the adhesive holding it in place. Stop when you reach the home button.
Apply a few drops of isopropyl alcohol to the base of the home button bracket.
Alternatively, you can use a heated iOpener to loosen the adhesive.
Insert the edge of an opening tool under the home button bracket lip.
Pry up with steady force to loosen the bracket.
crwdns2935267:0crwdne2935267:0Tesa 61395 Tape$5.99
Remove the home button bracket.
Scrape off as much of the old adhesive residue as you can, then clean it with acetone or high concentration (>90%) isopropyl alcohol.
Secure the bracket with E6000 glue, superglue, or high-strength double-sided tape. Make sure the bracket is aligned correctly before allowing your adhesive to cure, or the home button will not click when pressed.
Gently push the home button from the front of the display inward using the tip of a finger.
Remove all packing tape.
Peel any adhesive liners from the flex cables and press the cables in place onto the display panel.
Fold and connect the flex cable in the bottom left corner of the screen.
Don't peel and expose the perimeter adhesive until you've tested your repair and are ready to seal up the iPad.
crwdns2935229:088crwdne2935229:0
crwdns2944067:021crwdne2944067:0
Hello there OK so I have 2 screens with 2 different connectors one L shaped (which is on the new screen) and the old cracked screen has a rectangular type? I’m not sure rather it’s a 1gen/2nd gen type of problem? I’m about to grab my hot air gun to completely disassemble the cracked screen, as maybe I’m missing something? Any assistance is welcome… well actually please help me with this before I get a headache since this has totally frustrated me and i’ve had this sitting for nearly 2 1/2 months now but it’s about that time that I readdress this in attempt to fix it.
Hi, does your replacement screen have the home button assembly included? Otherwise there's need of soldering the assembly to it before it can be installed.
Dreetn -
hi
does anyone knows why there is a foam adhesive in thr back of the screen ? do i need to put back when i replaxe screen ?
thanks
I suppose the foam adhesive is similar to the one on the back of the 6s screens. I guess it has more of a heat dissipation function or is meant to absorb any pointy pressure points from inside that may develop (loose screw, sand, dirt...)
Dreetn -
hi
hope someone can help . i tested couple of screens before fitting them in they were working but once tech close it there no touch or black lcd (backlight on but no image )
NB : they disconnect battery before connecting Screen
