iPad Pro 12.9" 3rd Gen Screen Replacement
  1. iPad Pro 12.9" 3rd Gen Screen Replacement, Screen Replacement: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • iPad Pro 3rd Gen' A1895
    • Be Sure to turn off iPad by pressing and release the volume up button then volume down.
    • While Pressing and holding side button until screen turns off.
    • Just use the slider if you can.
    • Not powering it off can blow out your lcd back light just like iphones other ipads!
  2. iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You can use a heat gun or another handy heating method! MUST DO!
    • Heating the entire screen will help make it easy to safely remove the screen.
  3. iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After 15 Mins In Heater to loosen the strong adhesive!
    • Use a metal pry tool near the least broken shattered side.
    • Use a ifixit suction cup to pull up screen for a plastic guitar pick.
  4. iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply tape or adhesive over broken glass!
    • Bust out the metal pry tool lifting broken causing glass to stick to tape working your way around broken side.
    • Wiggle Jiggle the screen off the adhesive using multiple plastic guitar picks.
    • Do Not Tear the Screen Off!!!
  5. iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Do not rip the screen off!! Cables are very short will cause internal Damages!!!
    • On the Top of the screen the proximity sensor front camera has to be disconnected 1st.
  6. iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lay screen flat pull it down just enough to use a PH000 Screw drive to remove the safety bracket
    • Use Flat Ended Spoudger remove the bracken and cable from the Logic board!
  7. iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Perfect! Now Lift the screen folding it up to the left like so!
    • Remove 5 PH000 Screws protecting Power Connection and Display Cables
  8. iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • PH000 to Battery Connection
    • After detaching battery connection
    • Move Small cable is taped around edges up so you can properly disconnect battery connection
    • Remove all 3 ribbon cables from logic board with flat headed spudger!
  9. iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Just a touch of heat don't melt the thing off remove the face ID sensor from Old Screen.
    • Damaging Proximity sensor could effect True Tone with 3rd Party Parts
    • Gently use a tool to get under glued down connection on glass frame of screen!
  10. iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove Bracket off old screen you and move it to new screen
    • Transfer Cables and Bracket to new screen
  11. iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place Screen without adhesive test your screen and face ID
    • After running test take
  12. iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Clean Edges with flat ended metal tool to remove broken glass
    • Clean desk of glass on table get ready to remove Proximity sensor from old screen!
    • Do not clamp recommend to use flat and heavy object
    • Broken glass on the frame will crack your new screen
crwdns2935229:049crwdne2935229:0
Mark D Schlossman
crwdns2935283:009/25/19crwdne2935283:0
6,699 crwdns2915208:0crwdne2915208:0
crwdns2947412:040crwdne2947412:0
Most likely you may have damaged the flex of proximity sensor.
Check connector
Check placement with flash light make sure everything is aligned correctly
Mark D Schlossman -
why not get a new flex cable from ebay or aliexpress
imab -
What adhesive do you use to reattach their screen?
puppitkey - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 38
crwdns2936753:07crwdne2936753:0 221
crwdns2936753:030crwdne2936753:0 1,044
crwdns2942667:0crwdne2942667:0 74,628
