iPad Mini 6 Power Button Replacement
  1. iPad Mini 6 Power Button Replacement, Apply tape to a cracked screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini 6 Power Button Replacement, Apply tape to a cracked screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini 6 Power Button Replacement, Apply tape to a cracked screen: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  2. crwdns2944590:02crwdnd2944590:013crwdnd2944590:0crwdnd2944590:0crwdne2944590:0
    iPad Mini 6 Power Button Replacement, Heat the bottom edge: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Completely power off your device before you begin.
    • Apply a heated iOpener to the bottom edge of the device for 90 seconds to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  3. iPad Mini 6 Power Button Replacement, Screen removal information: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini 6 Power Button Replacement, Screen removal information: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini 6 Power Button Replacement, Screen removal information: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While you're waiting for the adhesive to loosen, note the following:
    • The areas at the top and bottom of the screen are sensitive to prying.
    • Don't insert a pick more than 3 mm to avoid damaging the screen.
    • There's a long circuit board attached to the screen that sits parallel to the left edge.
    • Don't insert a pick more than 1.5 mm to avoid damaging the circuit board.
    • The first two images are mirrored for demonstration purposes.
  4. iPad Mini 6 Power Button Replacement, Insert an opening pick: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini 6 Power Button Replacement, Insert an opening pick: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini 6 Power Button Replacement, Insert an opening pick: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the screen and the frame.
    • Insert an opening pick into the gap between the frame and the screen.
    • Don't insert the pick more than 1.5 mm to avoid damaging the circuit board.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  5. iPad Mini 6 Power Button Replacement, Separate the bottom adhesive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini 6 Power Button Replacement, Separate the bottom adhesive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini 6 Power Button Replacement, Separate the bottom adhesive: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the pick along the bottom edge of the device towards the bottom-right corner.
    • Leave the pick in to prevent the adhesive from resealing.
  6. iPad Mini 6 Power Button Replacement, Heat the right edge: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the right edge of the device for 90 seconds to loosen the adhesive underneath.
  7. iPad Mini 6 Power Button Replacement, Separate the bottom-right corner adhesive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini 6 Power Button Replacement, Separate the bottom-right corner adhesive: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini 6 Power Button Replacement, Separate the bottom-right corner adhesive: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the opening pick around the bottom-right corner of the device.
  8. iPad Mini 6 Power Button Replacement, Separate the remaining adhesive: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini 6 Power Button Replacement, Separate the remaining adhesive: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
    • When you slice near the front camera, don't insert the pick more than 1.5 mm to avoid damaging or smearing the camera.
  9. iPad Mini 6 Power Button Replacement, Reposition the screen: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini 6 Power Button Replacement, Reposition the screen: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini 6 Power Button Replacement, Reposition the screen: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If there's still resistance around the edges of the screen, use an opening pick to cut the adhesive again.
    • Don't try to remove the screen all the way yet; it's still connected to the frame by a flex cable.
    • With the bottom of the device facing you, pull the right edge of the screen up and towards the left edge of the device.
    • Rest the screen upside down and parallel to the frame before continuing.
    • Don't twist the screen or move it too far away from the frame to avoid damaging the flex cable.
  10. iPad Mini 6 Power Button Replacement, Unfasten the display cable bracket: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini 6 Power Button Replacement, Unfasten the display cable bracket: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the five 1.2 mm-long screws securing the frame bracket to the frame.
  11. iPad Mini 6 Power Button Replacement, Remove the display cable bracket: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini 6 Power Button Replacement, Remove the display cable bracket: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to remove the display cable bracket from the frame.
  12. iPad Mini 6 Power Button Replacement, Disconnect the display: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Mini 6 Power Button Replacement, Disconnect the display: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Mini 6 Power Button Replacement, Disconnect the display: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to pry up and disconnect the display cable's two press connectors secured to the frame.
  13. iPad Mini 6 Power Button Replacement, Remove the screen: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini 6 Power Button Replacement, Remove the screen: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screen from the frame.
  14. iPad Mini 6 Power Button Replacement, Disconnect the battery: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini 6 Power Button Replacement, Disconnect the battery: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The the flat end of a spudger to pry up and disconnect the battery's press connector secured to the frame.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  15. iPad Mini 6 Power Button Replacement, Unfasten the rear camera shield: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini 6 Power Button Replacement, Unfasten the rear camera shield: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the two 1.2 mm screws securing the rear camera shield to the frame.
  16. iPad Mini 6 Power Button Replacement, Remove the rear camera shield: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini 6 Power Button Replacement, Remove the rear camera shield: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to remove the rear camera shield.
  17. iPad Mini 6 Power Button Replacement, Disconnect the antenna: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini 6 Power Button Replacement, Disconnect the antenna: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to pry up and disconnect the antenna's coaxial cable.
    • During reassembly, these can be tricky to reconnect. Hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  18. iPad Mini 6 Power Button Replacement, Reposition the coaxial cable: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini 6 Power Button Replacement, Reposition the coaxial cable: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to pull the coaxial cable away from the frame, making sure to separate the tape keeping it in place.
  19. iPad Mini 6 Power Button Replacement, Disconnect the power button board: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini 6 Power Button Replacement, Disconnect the power button board: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to pry up and disconnect the power button board's press connector.
  20. iPad Mini 6 Power Button Replacement, Reposition the power button board's cable: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini 6 Power Button Replacement, Reposition the power button board's cable: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The power button board's cable is lightly adhered to the rear camera's press connector.
    • Gently peel back on the power button board's cable to separate it from the rear camera's press connector.
  21. iPad Mini 6 Power Button Replacement, Remove the tape: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini 6 Power Button Replacement, Remove the tape: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to remove the black tape on top of the power button board's ZIF connector.
  22. iPad Mini 6 Power Button Replacement, Disconnect the power button board's ZIF connector: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini 6 Power Button Replacement, Disconnect the power button board's ZIF connector: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the power button board cable's ZIF connector.
  23. iPad Mini 6 Power Button Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini 6 Power Button Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to pull the power button board's cable straight out of its ZIF connector on the frame.
  24. iPad Mini 6 Power Button Replacement, Remove the cable: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini 6 Power Button Replacement, Remove the cable: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezer, or your fingers, to remove the power button cable from the frame.
    • Since the cable is lightly adhered to the frame, you may feel some resistance.
  25. iPad Mini 6 Power Button Replacement, Unfasten the power button board: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini 6 Power Button Replacement, Unfasten the power button board: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the three screws securing the power button board to the frame:
    • One 2.2 mm screw
    • One 1.4 mm screw
    • One 1.7 mm screw
  26. iPad Mini 6 Power Button Replacement, Separate the power button board's adhesive: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini 6 Power Button Replacement, Separate the power button board's adhesive: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The power button board is lightly adhered to the frame.
    • Gently peel back on the power button board to separate its adhesive.
  27. iPad Mini 6 Power Button Replacement, Remove the power button: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini 6 Power Button Replacement, Remove the power button: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the tip of a spudger between the power button and the frame.
    • Pry sideways to separate the power button from the frame.
  28. iPad Mini 6 Power Button Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Mini 6 Power Button Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the power button.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad mini 6 Answers community for help.
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
164,558 crwdns2915208:0crwdne2915208:0
crwdns2935297:0769crwdne2935297:0
Staff
crwdns2935297:019,763crwdne2935297:0
Does changing the button disable Touch ID?
Alex - crwdns2934203:0crwdne2934203:0
It does disable touch ID.
William Loggarakis -
This guide isn't accurate to the iPad Mini 6
William Loggarakis - crwdns2934203:0crwdne2934203:0
Oof. This guide is not up to iFixit’s standards. It needs to be revisited!
Dave Nielsen - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 44
crwdns2936753:030crwdne2936753:0 194
crwdns2942667:0crwdne2942667:0 6,560
