iPad 4 CDMA Home Button Control Board Replacement
crwdns2942287:0crwdne2942287:0Prereq only for adhesive strips.
crwdns2944105:0crwdne2944105:0
Remove the two 2.1 mm Phillips #00 Phillips screws securing the home button control board to the home button mounting bracket.
Wedge the flat edge of a plastic opening tool in between the right end of the home button control board and the home button mounting bracket.
Depress the plastic opening tool downwards to pry the adhesive securing the home button control board from the home button mounting bracket.
Lift and remove the home button control board up off the home button mounting bracket.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use the flat edge of a spudger to scrape the old adhesive off the bottom right corner of the front panel assembly.
Gently place the home button control board on top of the home button mounting bracket.
Insert the two 2.1 mm Phillips #00 Phillips screws back into the home button control board to secure it against the home button mounting bracket.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
