crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0iMac M1 24"crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. iMac M1 24" Full Chip ID, iMac M1 24" Full Chip ID: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iMac M1 24" Full Chip ID, iMac M1 24" Full Chip ID: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Back side of the logic board:
    • Apple APL1102/339S00817 64-bit M1 8-core SoC (system on a chip).
    • SK hynix H9HCNNNCRMMVGR-NEH 8 GB (2 x 4 GB) LPDDR4 SDRAM memory
    • Kioxia KICM225VE4779 128 GB NAND Flash
    • Murata 339S00763 Wi-Fi/Bluetooth module
    • Apple APL1096/343S00474 power management IC
    • Apple APL1097/343S00475 power management IC
    • Richtek RT4541GQV power management IC
  2. iMac M1 24" Full Chip ID: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Back side of the logic board, continued:
    • Texas Instruments INA210 bi-directional current sense amplifier
    • Texas Instruments INA214 bi-directional current sense amplifier
    • Texas Instruments TPS62137 DC-DC converter
    • Dialog Semiconductor (formerly Silego) SLG59M301V 4-amp load switch
    • Texas Instruments SN74AVC4T234 4-bit bus transceiver
  3. iMac M1 24" Full Chip ID: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iMac M1 24" Full Chip ID: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Front side of the logic board:
    • Broadcom BCM57762 ethernet controller
    • Infineon (formerly Cypress Semiconductor) CYPDC1185B2-32LQXQ USB-C cable controller
    • Cirrus Logic CS42L83A audio codec
    • Analog Devices SSM3515B 31-watt class-D audio amplifier
    • Analog Devices (formerly Linear Technology) LTC3890-2 two-phase synchronous step-down converter
    • Texas Instruments TPS259827ON 15-amp eFuse with load current monitoring and transient fault management
  4. iMac M1 24" Full Chip ID: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Front side of logic board, continued:
    • Macronix MX25U6472F 64 MB serial NOR flash memory
    • Texas Instruments OPA333 single zero-drift CMOS operational amplifier
    • Temperature sensor (likely)
    • Nexperia (formerly NXP Semiconductor) 74AVC2T45 2-bit dual-supply voltage level translator/transceiver
    • Texas Instruments SN74AHC1G32 single 2-input OR gate
    • NXP Semiconductor SN210V NFC controller with secure element
  5. iMac M1 24" Full Chip ID: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iMac M1 24" Full Chip ID: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Interconnect board:
    • ASMedia ASM3142 PCIe-to-USB 3.1 Gen 2 controller
    • Texas Instruments CD3218B12 USB-C port/power delivery controller
    • Intel JHL8040R Thunderbolt 4 retimer
    • ASMedia ASM1543 10 Gbps 4:2 mux switch with USB 3.1 type-C compatibility
    • Texas Instruments TMP464 five-channel temperature sensor
  6. iMac M1 24" Full Chip ID: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Interconnect board, continued:
    • Winbond W25Q80DVUXIE 8 MB serial NOR flash memory
    • Texas Instruments INA231BIYFD 16-bit current/voltage/power monitor
    • Texas Instruments TMUX1108 1-channel analog multiplexer (likely)
    • Texas Instruments TLV75533P 500 mA LDO regulator
    • Maxim Integrated DC-DC converter
    • Nexperia (formerly NXP Semiconductor) 74AUP1G09 single AND gate
  7. iMac M1 24" Full Chip ID: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Nexperia (formerly NXP Semiconductor) LSF0101 1-bit bidirectional multi-voltage level translator
    • Texas Instruments SN74AXC1T45 dual-supply bus transceiver
    • Texas Instruments SN74AUP1G17 Schmitt trigger (likely)
  8. iMac M1 24" Full Chip ID: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iMac M1 24" Full Chip ID: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Left side of the display board:
    • Parade Technologies DP855A DisplayPort timing controller
    • Silicon Works SW50024 LCD level shifter
    • Winbond W25Q40EWUXIE 4 MB serial NOR flash memory
    • Texas Instruments TMP468 9-channel temperature sensor
    • Dialog Semiconductor (formerly Silego) SLG46826 mixed signal array
    • Analog Devices (formerly Linear Technology) LTC3115-1 2-amp synchronous buck converter
    • Texas Instruments TPS62140 2-amp step-down converter
  9. iMac M1 24" Full Chip ID: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iMac M1 24" Full Chip ID: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Right side of the display board:
    • Texas Instruments BUF18830 18-channel gamma-voltage generator
    • Richtek RT6811HGQV display power management
    • Texas Instruments TPS259571 eFuse with over-voltage protection
    • Texas Instruments TPS26621 800 mA eFuse with I/O reverse polarity protection
    • Texas Instruments 2N7001T 1-bit dual-supply buffered voltage signal converter
    • Texas Instruments TLV76701 1-amp LDO Regulator
    • Texas Instruments SN74LVC1G04 single inverter
  10. iMac M1 24" Full Chip ID: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iMac M1 24" Full Chip ID: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Left and right side of the display board, continued:
    • Texas Instruments OPA2810 dual rail-to-rail I/O operational amplifier
    • ON Semiconductor analog switch
    • Dialog Semiconductor load switch (likely)
    • Texas Instruments microcontroller (likely)
    • Texas Instruments regulator (likely)
    • Display drivers
  11. iMac M1 24" Full Chip ID: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iMac M1 24" Full Chip ID: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Texas Instruments DRV10975 BLDC motor driver
  12. iMac M1 24" Full Chip ID: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iMac M1 24" Full Chip ID: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iMac M1 24" Full Chip ID: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • A partial list of chips on the power supply board:
    • NXP Semiconductor TEA19161T digital power supply controller
    • NXP Semiconductor TEA19162T power factor correction controller
    • NXP Semiconductor TEA2095TE dual synchronous rectifier switching controller
Craig Lloyd
crwdns2935283:002/10/16crwdne2935283:0
40,805 crwdns2915208:0crwdne2915208:0
crwdns2935297:082crwdne2935297:0
76MiB of flash across the boards on this machine. Apple really does like large amounts of ROM, don’t they?
Saoirse Ó Catháin - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 45
crwdns2936753:030crwdne2936753:0 194
crwdns2942667:0crwdne2942667:0 17,523
