iMac LCD Cleanup
    1. iMac LCD Cleanup, LCD Dust removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    2. iMac LCD Cleanup: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Face the LCD down (be sure to have nothing between the screen and the table) ;
      • Remove 4 screws from the left bracket then 4 screws from the right bracket as displayed (the smallest is at the bottom) ;
    3. iMac LCD Cleanup: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iMac LCD Cleanup: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iMac LCD Cleanup: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a "Putty Knife" to separate brackets from the LCD panel frame as shown ;
      • Use a "Post-It" to keep the adhesive from the frame ;
      • Continue gently between the bracket and the frame ;
    4. iMac LCD Cleanup: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iMac LCD Cleanup: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the "Putty Knife" make a groove in the shield around the whole frame ;
      • Once done from the bottom center to the edges of the LCD panel unclip the frame (don't touch the top). Clips are located at :
      • Bottom left, center, right ;
      • Left bottom, top ;
      • Right bottom, top ;
      • Lift the frame 90° maximum ;
    5. iMac LCD Cleanup: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iMac LCD Cleanup: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iMac LCD Cleanup: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using gloves and a suction cup gently lift the LCD sheet (no more than 90° failing to do so may bend the LCD and cause image displaying issues);
      • Meticulously clean the inside. Do not use any detergent at most a very lightly humidified microfiber / lint-free cloth ;
      • Do not use an air spray as those might leave marks. Best to get rid of dust is a simple hair dryer going from the top center to the edges ;
      • Reassembly is going back those steps making sure to get rid of your finger-prints ;
crwdns2935229:021crwdne2935229:0
LLange
crwdns2935283:011/25/13crwdne2935283:0
1,017 crwdns2915208:0crwdne2915208:0
crwdns2947412:024crwdne2947412:0
Thank you for this guide! Helped me very much. And now my iMac is clean again :)
Robert - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I got the screen cleaned and all was well but when I returned everything back to the iMac the lower part of my screen didn't work...
Chris Malka - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
If the backligt is ok but no image check connections :
— To the logic board ;
— Then underneath the protective cover on the top of step 2 image…
If the backlight is not ok check the connector and the cable at the lower right corner of step 2 image.
Beware that if you have bended the LCD you might have damaged it.
LLange - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
It sounds like the LCD got bent then because the connections are fine so I just ordered a new LCD. But the guide was definitely helpful, I got the dust out!
Sorry about this I'm adding a warning on Step 5 to lift gently and no more than 90° hoping this might prevent others to have the same issue.
P.S. the LCD has an electronic board some times people have flickering issues after the display warmed-up. Thus changing that "inner-board" might solve their issue ⇒ after you receive your new LCD, try to sell the old display "inner-board" as well as the connectors…
crwdns2936753:07crwdne2936753:0 38
crwdns2936753:030crwdne2936753:0 172
crwdns2942667:0crwdne2942667:0 43,165
