prerequisite for logic board, heat sink, and CPU
            Remove the four 7.5 mm T8 screws from behind the GPU on the logic board.
            Remove the bracket from behind the GPU heat sink.
            Remove four black stickers from the back of the CPU heat sink.
            Remove four 12.3 mm T10 screws from the back of the CPU heat sink.
            Remove the spring plate from behind the CPU heat sink.
            Lift and remove the backing plate from behind the CPU heat sink. The backing plate has two posts that fit into alignment holes in the logic board.
            Lift the heat sink up from the logic board.
