crwdns2931315:0crwdnd2931315:0crwdne2931315:0
crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
Lay your iMac front side down on a table with the lower edge facing yourself.
Loosen the single Phillips screw in the center of the access door.
Remove the access door from your iMac.
crwdns2935267:0crwdne2935267:0Heavy-Duty Suction Cups (Pair)$14.95-
Stick two suction cups to opposing corners of the glass panel.
Gently pull the glass panel straight up off the iMac.
Remove the following 12 screws securing the front bezel to the rear case:
Eight 13 mm T8 Torx.
Four 25 mm T8 Torx.
Gently lift the front bezel from its top edge off the rear case.
Once the top edge of the front bezel has cleared the rear case, rotate the front bezel toward the stand and lift it off the rear case.
Rotate the front bezel away from the rest of the device and lay it above the top edge of the iMac.
Disconnect the microphone cable connector, removing tape as necessary.
Remove the two 5.3 mm T6 torx screws from the LCD connector.
Firmly grasp the pull tab on top of the connector and pull it straight up out of its port.
Remove the eight T8 Torx screws securing the display panel to the rear case.
Place your hands on either side of the bottom of the display panel, and lift it up enough that you can reach the connectors inside.
While holding the display panel up with one hand, locate and remove the display thermal sensor cable from its connector.
While still holding the display panel up, use two fingers to firmly push down on the power supply cable connector from its socket.
Lift and remove the display panel from the device.
Commencez par suivre l'excellent guide de Jeff Dickson du step 2 jusqu'au step 9 (demontage de la logic board)
Retirer les stickers de preuve de garantie.
Débrancher le capteur de temperature CPU.
Dévisser les 4 vis radiateur a l'aide du tournevis Philips #2
Retourner la logic board
Finir de dévisser et retirer les 4 vis torx 8
Nettoyer le surplus de pate thermique à l'aide d'un chiffon propre et d'une solution alcoolique.
Dévisser d'un demi tour la vis de blocage du CPU à l'aide d'un petit tournevis plat.
Retirer délicatement le processeur en le tirant verticalement.
Aligner le nouveau processeur grâce au détrompeur.
Deposer le nouveau processeur verticalement dans son logement.
Revisser la vis de blocage d'un demi tour.
Deposer un peu de pâte thermique sur le centre du CPU.
crwdns2917034:0crwdne2917034:0
Anyone have any tips or advice as to what CPUs would work best?
