iMac Intel 24" EMC 2111 GPU Assembly Replacement
    1. iMac Intel 24" EMC 2111 GPU Assembly Replacement, Access Door: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iMac Intel 24" EMC 2111 GPU Assembly Replacement, Access Door: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Loosen the two Phillips screws securing the access door to your iMac.
      • Both screws remain captive within the access door.
      • Remove the access door.
    1. iMac Intel 24" EMC 2111 GPU Assembly Replacement, Front Bezel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the following screws along the lower edge of your iMac:
      • Three 6 mm T8 Torx screws
      • One 8 mm T8 Torx screw
    2. iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lay your iMac stand-side down on a flat surface.
      • To lift the front bezel off the iMac, simultaneously:
      • Use your thumbs to press in the RAM arms and hold the iMac down.
      • Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
      • Pull the front bezel up with your index fingers.
      • Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
    3. iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift the front bezel off the rear case and rotate it away from the bottom edge of the iMac, minding the camera and microphone cables still attached to its upper edge.
      • The third picture shows the top front bezel brackets and their slots cut into the top edge of the iMac's rear case.
      • Do not completely remove the front bezel, as it is still attached by the camera/microphone cables.
    4. iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • If necessary, remove the strip of tape covering the microphone cable connector.
      • The microphone connector is located near the inside of top edge of your iMac.
    5. iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Disconnect the microphone cable.
      • Disconnect the camera cable by pulling its connector away from the socket on the camera board.
      • The camera cable connector and socket are delicate and easily bent. Remove with caution.
    1. iMac Intel 24" EMC 2111 GPU Assembly Replacement, Display Assembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iMac Intel 24" EMC 2111 GPU Assembly Replacement, Display Assembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Peel the two highlighted EMI shield tabs off the frame of the LCD.
    2. iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two T6 Torx screws securing the display data cable to the logic board.
    3. iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the black plastic tab attached to the display data cable connector to disconnect it from the logic board.
    4. iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use your fingertips to pull both sides of the wide inverter cable connector out of its socket on the logic board.
      • De-route the inverter cable from its location next to the CPU fan.
    5. iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Before attempting this step, we recommend laying your iMac stand-side down on a table to avoid the display falling down.
      • Remove the eight T8 Torx screws securing the display assembly to the rear case.
      • It is helpful to use a thin magnetized screwdriver to remove these screws.
    6. iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the display assembly from the iMac.
    1. iMac Intel 24" EMC 2111 GPU Assembly Replacement, Right Speaker: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iMac Intel 24" EMC 2111 GPU Assembly Replacement, Right Speaker: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Peel back the piece of EMI tape connecting the bottom edge of the right speaker to the metal frame of the iMac.
      • Peel the tape away from the lower corner of the right speaker.
    2. iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • De-route the right-hand speaker's cable from between the logic board and the optical drive fan.
      • Disconnect the cable from the logic board.
    3. iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 26 mm T10 Torx screw securing the right speaker to the iMac.
    4. iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the right speaker away from the logic board and remove it from the iMac.
    1. iMac Intel 24" EMC 2111 GPU Assembly Replacement, Logic Board: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iMac Intel 24" EMC 2111 GPU Assembly Replacement, Logic Board: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the flat end of a spudger to pry both antenna connectors off their sockets on the AirPort card.
      • The black antenna attaches closest to the bottom edge of the iMac.
    2. iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use both fingertips to disconnect the camera and microphone cable from its socket on the logic board.
      • Pull the connector perpendicular to the face of the logic board.
    3. iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the optical drive fan connector toward the top edge of the iMac to disconnect it from the logic board.
    4. iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the left speaker connector toward the top edge of the iMac to disconnect it from the logic board.
    5. iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the optical drive thermal sensor connector toward the right side of the iMac to disconnect it from its socket.
    6. iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • If necessary, remove the strip of tape covering the optical drive connector.
    7. iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Gently pull the cable retainer on the optical drive cable ZIF socket toward the right side of the iMac.
      • The retainer should move about 1 mm and stop. Do not attempt to remove the retainer.
      • Pull the optical drive ribbon cable out of its socket, being careful not to rip it in the process.
    8. iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the hard drive thermal sensor and hard drive fan cables from the logic board by pulling their connectors toward the top edge of the iMac.
    9. iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the CPU fan connector toward the left edge of the iMac to disconnect it from the logic board.
    10. iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Disconnect the power button cable from the logic board.
      • Pull its connector perpendicular to the face of the logic board.
    11. iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the flat end of a spudger to pry the single Bluetooth antenna off its socket on the Bluetooth board.
    12. iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the ambient temperature sensor cable perpendicular to the face of the logic board to disconnect it from its socket.
    13. iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Disconnect the DC-In cable from the logic board by pulling its cable toward the right side of the iMac while depressing its locking mechanism.
      • It is helpful to use a spudger and pry from alternating sides of the connector to help "walk" it out of its socket.
    14. iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pull the hard drive SATA data cable perpendicular to the face of the logic board to disconnect it from its socket.
      • To avoid damaging the socket on the logic board, we recommend using a metal spudger to help separate the SATA data cable and its socket.
    15. iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Peel the foam tape off the top edge of the heat sink framework.
    16. iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the following ten screws:
      • Three 6.6 mm T10 Torx fine thread screws
      • Three 7 mm T10 Torx coarse thread screws
      • Two 9.3 mm T10 Torx coarse thread screws
      • Two 5.3 mm T10 Torx coarse thread screws
    17. iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull the right edge of the logic board slightly away from the rear case to dislodge the rear I/O ports from their bezel.
      • Tilt the top edge of the board away from the rear case and lift the logic board assembly out of the rear case, minding any cables that may get caught.
      • When reinstalling the logic board, it is helpful to use tape to temporarily tuck the cables out of the way until the board is properly seated in the rear case.
      • During reassembly of the logic board, pay attention to the position of the I/O connectors. When the board is back in the case, insert a USB or Thunderbolt cable into one of the connectors to align it perfectly.
    1. iMac Intel 24" EMC 2111 GPU Assembly Replacement, GPU Assembly: crwdns2935265:034crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the short T10 Torx screw securing the GPU heat sink to the metal logic board framework.
      • This picture was taken with the top edge of the logic board nearest the bottom of the picture.
    2. iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:035crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the GPU thermal sensor cable from the logic board.
    3. iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:036crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two T8 Torx screws securing the GPU to the logic board.
    4. iMac Intel 24" EMC 2111 GPU Assembly Replacement: crwdns2935265:037crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Angle the top edge of the GPU away from the logic board and pull it out of its socket on the logic board.
      • Remove the GPU assembly.
crwdns2935229:027crwdne2935229:0
crwdns2947412:07crwdne2947412:0
Competed the GPU replacement following this excellent guide. My iMac is as good as new, after weeks/months of randomly fragmented windows. Would not rate the repair as difficult, though, since no soldering/desoldering was required. Took between 4.5 and 5 hours (forgot to check the exact start time).
Bruce Pinkney - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
thx for yout reply. And i have a question.
I have done all these works. But i can't get the replacement of the GPU.
can i ask you where to get the replacement of the GPU?
it is very hard to find the GPU because it is pretty old model
hutch - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hmm i have a problem with the graphics card with the imac and i need a card where i can find one....
zepa19 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Having similar issues with fragmented windows and then freezing in some cases. Very certain it is the GPU - do I replace the paste or the board?
frasermackie - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Fraser, I suggest checking a youtube video on how to reset the GPU's solder connections. Apparently, with the overheating the solder connections loosen causing the fragmented windows and then freezing. Normally one would replace the GPU assembly, but since these are extremely hard to find and costly, resetting the solder connections might be the only option to try.
At YouTube.com search for "Casual iMac Video Card Repair".
I've been meaning to try this repair for two years now . . . finally going to give it a try.
Ewald - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 35
crwdns2936753:030crwdne2936753:0 151
crwdns2942667:0crwdne2942667:0 37,409
