Upgrade your RAM for an instant increase in speed.
Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
Remove the access door from your iMac.
Use the sharp tip of a spudger to pull the black plastic RAM tabs out of the memory bay.
Pull the black plastic RAM tab away from your iMac to eject the RAM chip.
Grab the RAM chip by its edges and pull it straight out of its slot.
crwdns2935229:0111crwdne2935229:0
crwdns2917034:0crwdne2917034:0
There needs to be a little bit of important discucssion about getting the new RAM properly seated into the slots. Otherwise, great instructions!
In order for the logic board to come out cleanly, one should remove the RAM at the end of this step.
kevmacmills - crwdns2934203:0crwdne2934203:0
Definitely! The author should make this as a step in the description (because not everyone reads Comments)
finnik2d - crwdns2934203:0crwdne2934203:0
Just did this procedure and the RAM must absolutely come out for the logic board to come free later.
matt - crwdns2934203:0crwdne2934203:0
