This guide is an internal prerequisite that should remain unpublished.
If present, remove the pieces of clear tape securing the ambient temperature sensor cable and the left speaker cable to the rear case.
Remove the two 13 mm T10 Torx screws securing the CPU fan to the outer case.
Peel the cable retainer off the side of the CPU fan.
Remove the CPU fan from the outer case, minding any cables that may get caught.
De-route the left speaker cable from the clips securing it to the outer case.
Carefully remove the left speaker and ambient temperature sensor cables from the CPU fan cable retainer.
