Easily replace your BR 2032 lithium coin-cell PRAM battery.
            Lay your iMac front side down on a table with the lower edge facing yourself.
            Loosen the single Phillips screw in the center of the access door.
            Remove the access door from your iMac.
   crwdns2935267:0crwdne2935267:0Heavy-Duty Suction Cups (Pair)$14.95-
            Stick two suction cups to opposing corners of the glass panel.
            Gently pull the glass panel straight up off the iMac.
            Remove the following 12 screws securing the front bezel to the rear case:
            Eight 13 mm T8 Torx.
            Four 25 mm T8 Torx.
            Gently lift the front bezel from its top edge off the rear case.
            Once the top edge of the front bezel has cleared the rear case, rotate the front bezel toward the stand and lift it off the rear case.
            Rotate the front bezel away from the rest of the device and lay it above the top edge of the iMac.
            Disconnect the microphone cable connector, removing tape as necessary.
            Use the tip of a spudger to pry the PRAM battery out of its holder.
