Removing the hard drive.
To remove the hard drive bracket, squeeze the middle against the side of the hard drive while rotating the top left edge toward yourself.
After the left edge has been freed, rotate the bracket toward the right edge of the hard drive.
Lift the hard drive bracket straight up off the chassis.
If present, remove the small piece of tape covering the hard drive and optical drive temperature sensor cables.
Pull the hard drive temperature sensor cable straight away from its socket on the logic board.
Rotate the top of the drive toward yourself, then lift the hard drive straight up off its lower pins.
Insert the flat end of a spudger between the SATA data cable and the edge of the hard drive.
Twist the spudger to separate the SATA data cable from the hard drive.
Disconnect the SATA data cable from the hard drive.
Lift the hard drive out of your iMac, minding the thermal sensor cable that may get caught.
