iMac Intel 20" EMC 2133 and 2210 RAM Replacement
    1. iMac Intel 20" EMC 2133 and 2210 RAM Replacement, Access Door: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Loosen the single Phillips screw in the center of the access door.
      • This screw is captive in the access door.
      • Remove the access door from your iMac.
    1. iMac Intel 20" EMC 2133 and 2210 RAM Replacement, RAM: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iMac Intel 20" EMC 2133 and 2210 RAM Replacement, RAM: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the tip of a spudger to pull the black plastic RAM tabs out of the memory bay.
      • Pull the black plastic RAM tab away from your iMac to eject the RAM chip.
    2. iMac Intel 20" EMC 2133 and 2210 RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Grab the RAM chip by its edges and pull it straight out of its slot.
      • If two RAM chips are installed, repeat this process for the other chip.
crwdns2935229:0164crwdne2935229:0
Walter Galan
711,115 crwdns2915208:0crwdne2915208:0
crwdns2935297:01,203crwdne2935297:0
crwdns2947412:012crwdne2947412:0
I currently have a 4GB memory module installed on an EMC 2210 in one of the memory slots. Can I still install the original 1GB ram in the other slot making it 5GB total memory?
richt0812 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I installed 2GB x2 to mine to upgrade from 1GB x2. It took just minutes and I used a regular philips screw driver I found around home. Pull hard on the black straps to get the memory out. It is working great with no problems. Good luck!
1tom2go - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thank you for the guide. I had 2GB. I took out 1 module to add a 4GB module. So easy and now my 2133 iMac is jaw dropping fast.
Garison
garison - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hi Garison,
I hope you can answer my question. I have an iMac, medio 2007, Intel 20" EMC 2133.
RAM: (1GB + 1GB) 667 MHz DDR2 SDRAM.
I would like to make my iMac "jaw dropping fast" as well ;-)
Is it PC 5300 or PC 6400 I should buy?
And what setup wold you recommend? (1GB + 2GB), (1GB + 4GB), (2GB + 2GB) or (2GB + 4GB)?
Thanks,
Mikkel
mipedersen - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 45
crwdns2936753:030crwdne2936753:0 134
crwdns2942667:0crwdne2942667:0 111,836
