Regain Bluetooth functionality by replacing the Bluetooth board.
Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
Loosen the three Phillips screws securing the rear panel to the iMac.
Lift the rear panel slightly near the bottom of the iMac.
Pull the rear panel toward yourself and remove it from the iMac.
Remove the two 5.5 mm T6 Torx screws securing the Bluetooth board to the logic board.
Bend a paper clip into a hook and use it to pull the Bluetooth board up off its socket on the logic board.
Use a spudger to pry the Bluetooth antenna connector up off the Bluetooth board.
crwdns2917034:0crwdne2917034:0
Greetings Walter Galan, I would like to know if I can install this iMac G5 20" Model A1076 Bluetooth board into my iMac 21 system, it say’s that no wireless is installed.
Please Advise!
Thank You In Advance & Have A Good One!!!.
R.Askew
Some models (with light sensor) have only the two outboard screws.
Robert Huber - crwdns2934203:0crwdne2934203:0
