Removing the logic board assembly to replace it with a new one.
Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
Carefully remove the base access panel.
Remove the four 25mm T-15 screws.
Open the housing plate.
A fixed plug connector between the logic board and upper unit will cause some resistance. Pull gently but firmly.
Gently remove the cables marked in red.
Remove the three metal 10mm T-15 screws.
Remove the one nylon 10mm T-15 screw.
Using thumbs and forefingers, firmly grasp the battery holder in one hand while grasping the metal bar in the other. Gently lift and pull the logic board to release it.
crwdns2935229:09crwdne2935229:0
crwdns2917034:0crwdne2917034:0
We need to say what cables to remove in step 6 of Logic Board Assembly
