Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
Carefully remove the base access panel.
Remove the four 25mm T-15 screws.
Open the housing plate.
A fixed plug connector between the logic board and upper unit will cause some resistance. Pull gently but firmly.
Remove the 2 torx 10mm screws on the EMI shield
Carefully remove shield and copper tape
Remove the 4 10mm torx screws attatched to the drive carrier.
Grasp the carrier with both hands on each side.
Remove the carrier by lifting up and out.
Flip the removed carrier to the right and pull out power cables.
What two screws in step 6
We need a "action" shot; we need to show an actual screwdriver unscrewing the screw.
