Remove bottom housing to reveal the inside of the iMac.
Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
Carefully remove the base access panel.
Remove the four 25mm T-15 screws.
Open the housing plate.
A fixed plug connector between the logic board and upper unit will cause some resistance. Pull gently but firmly.
crwdns2917034:0crwdne2917034:0
If you do this - don't you still need to apply a fresh coat of thermal paste to the exposed ends of the two heat-sink posts (that separate when you open a G4 flatpanel this far) - my understanding was that the machine would overheat and you'd be left with didley squat!!
Gregg :O)
