iMac G4 15" 700 MHz EMC 1873 RAM SO-DIMM Replacement
  1. iMac G4 15" 700 MHz EMC 1873 RAM SO-DIMM Replacement, Outer Base Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iMac G4 15" 700 MHz EMC 1873 RAM SO-DIMM Replacement, Outer Base Plate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the computer monitor face down on a safe, harmless surface.
    • Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
  2. iMac G4 15" 700 MHz EMC 1873 RAM SO-DIMM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the metal plate from bottom of the iMac G4.
    • The four screws do not completely separate from the metal plate.
  3. iMac G4 15" 700 MHz EMC 1873 RAM SO-DIMM Replacement, RAM DIMM: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iMac G4 15" 700 MHz EMC 1873 RAM SO-DIMM Replacement, RAM DIMM: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
    • These tabs lock the module in place and releasing them will cause the module to "pop" up.
    • Remove the RAM module from the iMac.
crwdns2935229:010crwdne2935229:0
Ryan Kozak
crwdns2935283:010/10/11crwdne2935283:0
1 675 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 5-32, Amido Fall 2011 crwdns2935289:0Cal Poly, Team 5-32, Amido Fall 2011crwdne2935289:0
CPSU-AMIDO-F11S5G32
Please correct the title, this is a 144 pin SODIMM, it is not a DIMM
The 168 pin DIMM is used in the internal socket.
Canadaram - crwdns2934203:0crwdne2934203:0
Thanks For catching this Typo! :-)
Ben Capehart -
crwdns2942667:0crwdne2942667:0 5,718
