If you thought that your Lexus IS F-sport could never have fog lights, think again! These iJDMTOY IS F-sport fog lights give you a JDM look and style.
Turn wheel and open wheelbase plastic cover to access back of fog lights.
Remove fog lamp location plastic insert.
Use one hand to support the plastic insert in front and use another hand to push it out.
You may notice there is a slight gap when you put back the LED fog lamp....this is normal!
Replace back with the new iJDMTOY Lexus IS250 IS350 F-Sport LED FOg Lights.
Insert LED fog light starting with the corner that has the longest tab. Gradually ease the LED fog light in with the middle length tabs. Push the short tab at the end to lock.
Locate stock LED DRL adapter below headlamp and unplug.
Use the middle wire and striped wire. Tap red wire of the LED fog lights to the middle wire and tap black wire of the LED fog lights to striped wire.
Test to see if the Lexus F-Sport LED fog lights work.
Repeat the process on the other side.
It's very straightforward to install iJDMTOY 2014 Lexus IS F-Sport Fog Lights!
