iHome iPL8 Lightning Connector Replacement
  1. iHome iPL8 Lightning Connector Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device over to access the bottom panel.
    • Locate the 6mm Phillips #2 screw under the label "unscrew to open door."
  2. iHome iPL8 Lightning Connector Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #2 screwdriver, unscrew the captive screw.
    • Keep turning until the screw and the door are loose.
  3. iHome iPL8 Lightning Connector Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and remove the battery access panel.
    • The captive screw will remain attached to the panel.
  4. iHome iPL8 Lightning Connector Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iHome iPL8 Lightning Connector Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently press on the rim of the 3V battery.
    • Remove the 3V battery.
  5. iHome iPL8 Lightning Connector Replacement, Lightning Connector: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Keeping your device upside-down, locate the four 6mm Phillips #2 screws near each corner.
    • Remove the four 6mm Phillips #2 screws.
  6. iHome iPL8 Lightning Connector Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four round pads from the bottom of the device.
    • There are two additional 6mm Phillips #2 screws under the pads.
    • Using a Phillips #2 screwdriver, remove the two remaining screws.
    • Put your hand on the silver bottom case and gently pull it outward.
  7. iHome iPL8 Lightning Connector Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iHome iPL8 Lightning Connector Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the green circuit board. This panel is clipped onto two black, circular-shaped columns at two corners.
    • Pull out the green circuit board on the two corners.
    • The green circuit board is attached to a black box at the bottom. Flip the panel and the black box together to open the device.
  8. iHome iPL8 Lightning Connector Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iHome iPL8 Lightning Connector Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 2.5 mm Phillips #1 screws securing the lightning dock assembly to the device.
    • Remove the two screws and the black cover.
    • Gently remove the lightning dock assembly.
    • The lightning dock assembly is connected to wires.
  9. iHome iPL8 Lightning Connector Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iHome iPL8 Lightning Connector Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iHome iPL8 Lightning Connector Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 2.5mm screws using a Phillips #1 screwdriver.
    • Remove the back cover.
    • Use your fingers to reposition the lightning connector.
    • Make sure ALL of the lightning connector is exposed.
Chen Zhong
crwdns2935283:002/05/19crwdne2935283:0
569 crwdns2915208:0crwdne2915208:0
UC Davis, Team S18-G5, Lore Winter 2019 crwdns2935289:0UC Davis, Team S18-G5, Lore Winter 2019crwdne2935289:0
UCD-LORE-W19S18G5
where can I find the replacement lightning connector?
Bond 007 and a Half - crwdns2934203:0crwdne2934203:0
Greetings, did you ever find the connector replacement? I am asking so that I can purchase. Thank you in advance for your reply.
Shawn Simmons -
I’m trying to find the replacement part to buy too.
Wendy - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 804
