This guide instructs you to replace the battery in an iHome iPL8. The process includes using screwdriver and removing bottom door of the device to detach the battery.
Turn the device over to access the bottom panel.
Locate the 6mm Phillips #2 screw under the label "unscrew to open door."
Using a Phillips #2 screwdriver, unscrew the captive screw.
Keep turning until the screw and the door are loose.
Lift and remove the battery access panel.
Gently press on the rim of the 3V battery.
Remove the 3V battery.
