Use this guide to replace the buttons (alarm, hour, minute, power, play/pause, and volume) on the top of the iHome.
Unscrew the four 13mm Phillips #1 screws, located in the 4 indented holes on the back of the iHome.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Pull front cover directly out and away from iHome base.
Pulling firmly should detach the cable on the bottom right. If not, use the tweezers to firmly pull the cable out of its socket.
Lay the front cover face down.
Pinch the cable on the left and firmly pull it out of its socket.
Remove the four 10mm Phillips #1 screws located on either side of the speaker.
Pinching the speaker with your thumb and pointer finger, pull it firmly down and out, away from the housing.
If the speaker is difficult to pull out, push down on the buttons from the top to help loosen it.
Remove the four 8mm Phillips #0 screws from the top of the speaker.
Remove the two rows of buttons and replace.
