iHome iP41BR Top Buttons Replacement
  1. iHome iP41BR Top Buttons  Replacement, Remove Front Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug your iHome before starting disassembly.
    • Unscrew the four 13mm Phillips #1 screws, located in the 4 indented holes on the back of the iHome.
  2. iHome iP41BR Top Buttons  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull front cover directly out and away from iHome base.
    • Pulling firmly should detach the cable on the bottom right. If not, use the tweezers to firmly pull the cable out of its socket.
  3. iHome iP41BR Top Buttons  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the front cover face down.
    • Pull the cover away from the housing gently to ensure no damage is done to the ribbon cable or the soldered connections.
    • Pinch the cable on the left and firmly pull it out of its socket.
  4. iHome iP41BR Top Buttons  Replacement, Detach Speaker: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 10mm Phillips #1 screws located on either side of the speaker.
  5. iHome iP41BR Top Buttons  Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iHome iP41BR Top Buttons  Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pinching the speaker with your thumb and pointer finger, pull it firmly down and out, away from the housing.
    • If the speaker is difficult to pull out, push down on the buttons from the top to help loosen it.
  6. iHome iP41BR Top Buttons  Replacement, Remove Buttons: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 8mm Phillips #0 screws from the top of the speaker.
    • Remove the two rows of buttons and replace.
Paige Reisman
crwdns2935283:007/11/16crwdne2935283:0
201 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 99
