iHome iP21 Docking Station Pin Replacement
  1. iHome iP21 Docking Station Pin Replacement, Base: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iHome iP21 Docking Station Pin Replacement, Base: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iHome iP21 Docking Station Pin Replacement, Base: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws.
    • Unscrew the four 11mm screws from the base.
    • Pry the base loose using the spudger.
    • Remove the base by hand.
  2. iHome iP21 Docking Station Pin Replacement, Housing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iHome iP21 Docking Station Pin Replacement, Housing: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two black 6mm screws connecting the main circuit board to the housing top.
    • Gently pull front housing from the back housing.
  3. iHome iP21 Docking Station Pin Replacement, 30-pin docking mount: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the 30-pin docking mount on the iP21. The 30-pin docking mount is visible on top of the iP21.
  4. iHome iP21 Docking Station Pin Replacement, Protective cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iHome iP21 Docking Station Pin Replacement, Protective cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 4mm screws from the protective cover using the iFixit Phillips #1 bit
  5. iHome iP21 Docking Station Pin Replacement, Ribbon cables: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iHome iP21 Docking Station Pin Replacement, Ribbon cables: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iHome iP21 Docking Station Pin Replacement, Ribbon cables: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grasp plastic cable connector ends
    • Remove the mini circuit board with 30-pin mounting dock from the two black plastic pegs.
    • Rock gently back and forth and pull to detach mini circuit board with 30-pin mounting dock attached.
Brandy
crwdns2935283:010/27/14crwdne2935283:0
601 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 1-2, Carnegie Fall 2014 crwdns2935289:0Eastern Washington University, Team 1-2, Carnegie Fall 2014crwdne2935289:0
EWU-CARNEGIE-F14S1G2
crwdns2931471:06crwdne2931471:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 814
