Use this guide to replace your iHome iP1's damaged or faulty motherboard. The motherboard is located on the back of your iHome iP1 and is protected by its back cover. Although the motherboard connects all of the electronic parts in the iHome iP1, it is relatively simple to remove.
Orient the iHome upside down with the speakers facing away from you.
Remove the four 9.5 mm Phillips #2 screws located on each of the four corners of the iHome's back cover.
Remove the back cover by grabbing its sides and lifting it off the iHome.
Disconnect all five wire bundles attached to the motherboard by pulling them away from their connection.
Unscrew the four 9.5 mm Phillips #2 screws on the four metal brackets located at each corner of the motherboard.
Unscrew the grey 6.0 mm Phillips #1 screw directly above the red, blue, and green component ports.
Remove the motherboard from its housing by grabbing it near its edges and carefully pulling it upward.
crwdns2947412:05crwdne2947412:0
Easy to do,
but where can i buy a new motherboard ?
reagrds
Joerg (ifixit@xyz.logopainter.de)
I have the same problem ? Where I can obtain a new motherboard ?
Stefano Antoniutti
anto5657@alice.it
Were you able to buy the motherboard?
Rodrigo -
Rodrigo
rodrigo@r7criacoes.com.br
i also facing same issue, where can i get new motherboard ?
riyupc123@gmail.com
necesito toda la placa madre o el diagrama para pedir una peque;a pieza que se quemo
Teodoro De la o - crwdns2934203:0crwdne2934203:0
