iHome iP1 Motherboard Replacement
  1. iHome iP1 Motherboard Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient the iHome upside down with the speakers facing away from you.
    necesito toda la placa madre o el diagrama para pedir una peque;a pieza que se quemo
    Teodoro De la o - crwdns2934203:0crwdne2934203:0
  2. iHome iP1 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iHome iP1 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 9.5 mm Phillips #2 screws located on each of the four corners of the iHome's back cover.
  3. iHome iP1 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover by grabbing its sides and lifting it off the iHome.
  4. iHome iP1 Motherboard Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iHome iP1 Motherboard Replacement, Motherboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect all five wire bundles attached to the motherboard by pulling them away from their connection.
    • The order in which the wire bundles are removed does not matter.
    • You may need to remove some black foam tape in order fully disconnect some of the wires.
  5. iHome iP1 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iHome iP1 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the four 9.5 mm Phillips #2 screws on the four metal brackets located at each corner of the motherboard.
  6. iHome iP1 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iHome iP1 Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the grey 6.0 mm Phillips #1 screw directly above the red, blue, and green component ports.
  7. iHome iP1 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iHome iP1 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iHome iP1 Motherboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the motherboard from its housing by grabbing it near its edges and carefully pulling it upward.
Sachin Shenoi
crwdns2935283:010/10/16crwdne2935283:0
336 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 20-1, Livingston Fall 2016 crwdns2935289:0Cal Poly, Team 20-1, Livingston Fall 2016crwdne2935289:0
CPSU-LIVINGSTON-F16S20G1
crwdns2947412:05crwdne2947412:0
Easy to do,
but where can i buy a new motherboard ?
reagrds
Joerg (ifixit@xyz.logopainter.de)
Joerg Peters - crwdns2934203:0crwdne2934203:0
I have the same problem ? Where I can obtain a new motherboard ?
Stefano Antoniutti
anto5657@alice.it
Stefano Antoniutti - crwdns2934203:0crwdne2934203:0
Were you able to buy the motherboard?
Rodrigo -
Rodrigo
rodrigo@r7criacoes.com.br
Rodrigo - crwdns2934203:0crwdne2934203:0
i also facing same issue, where can i get new motherboard ?
riyupc123@gmail.com
Riyu PC - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 1,948
