Use this guide to replace your iHome iP1's damaged or faulty command buttons. These buttons are located on the front of the iPod/iPhone dock and are used pause/play music and change the volume of the speakers.
Orient the iHome upside down with the speakers facing you.
Remove the two 9.5 mm Phillips #1 screws from the dock cover.
Remove the dock cover by grabbing its sides and pulling it up and away from the faceplate.
Disconnect the silver ribbon cable on the left-hand side by pulling away from the command buttons.
Remove the command buttons by pulling the small black panel containing them downward and away from the faceplate.
Where can I buy the button PCB
David Ivar - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
