This guide will walk you through replacing the rechargeable battery in the speaker.
Push down and turn the top of the speaker clockwise. This will release the clips and expand the speaker.
Use a #000 Phillips screwdriver to remove the four 1 mm screws from the bottom half of the speaker.
Flip the speaker over and use a #000 Phillips screwdriver to remove three 1mm screws . Unscrew these to unfasten the top.
Remove the now unfastened coverings to expose the internals of the speaker.
Locate the battery underneath the circuit board.
Unsolder the batterie's wires from the circuit board to remove the old battery.
To reassemble your device, follow Steps 1-4 in reverse order.
