iHome iH8BR Scroll Wheel Replacement
  1. iHome iH8BR Scroll Wheel Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iHome iH8BR Scroll Wheel Replacement, Lower Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iHome iH8BR Scroll Wheel Replacement, Lower Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the device from the wall outlet, and turn it over so that the buttons are on a flat surface.
    • Use your fingers to pinch the tab in the direction of the "Open" arrow until tab is loose. Pull the tab vertically to remove it.
    • Remove the battery cover and the batteries.
  2. iHome iH8BR Scroll Wheel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iHome iH8BR Scroll Wheel Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide a spudger under the two front rubber pads to expose two hidden screws.
  3. iHome iH8BR Scroll Wheel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following eight screws:
    • Four 15.1 mm Phillips #2 screws near the front of the device.
    • Four 12.7 mm Phillips #2 screws near the back of the device.
    • The slots for the four 12.7 mm screws are very narrow, so you will need a slender, Phillips #2 screwdriver that does not feature replaceable heads in order to reach them.
  4. iHome iH8BR Scroll Wheel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iHome iH8BR Scroll Wheel Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the iHome 180 degrees so the speaker grille is facing you. Carefully lift the bottom case away from the rest of the body and tilt it as shown.
    • Be careful and do not yank the bottom case. A white ribbon wire is the only thing that connects the bottom case to the rest of the device.
    • Using a pair of tweezers, detach the white ribbon cable. Make sure to pull on the ribbon, not on the head.
    • The lower case can now be completely removed from the device!
  5. iHome iH8BR Scroll Wheel Replacement, Motherboard Assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iHome iH8BR Scroll Wheel Replacement, Motherboard Assembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four screws attaching the top of the case to the motherboard:
    • Two 9.5 mm Phillips #2 screws near the speaker grille.
    • Two 14.3 mm Phillips #2 screws that sit in recesses under the motherboard.
    • It is useful to use a screwdriver with a magnetic tip so that the screws don't get lost inside the device.
  6. iHome iH8BR Scroll Wheel Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iHome iH8BR Scroll Wheel Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the iHome 180 degrees and carefully pull up on speaker cases to pry them loose from the bottom case.
    • Prying the Motherboard Assembly from the Upper Case will require a good amount of force. Be very careful not to break the case, or yank on any of the ribbon wires attached to the underside.
    • Pulling outwards on the sides of the Upper Casing can help loosen the assembly.
    • If it seems too difficult to remove, chances are that a screw is still attached. Make sure you've removed every screw listed before proceeding to this step.
    • Pull the back adapter cover off.
  7. iHome iH8BR Scroll Wheel Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iHome iH8BR Scroll Wheel Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 6.4 mm Phillips #1 screws holding the adapter to the outer case.
    • Only remove the following screws if you are planning on taking apart the iPod Adapter later on:
    • Two 6.4 mm Phillips #1 screws near the center of the adapter. These screws have built in washers.
    • One 4.0 mm Phillips #1 screw near the center of the adapter.
    • The iPod adapter should now be separate from the upper casing.
  8. iHome iH8BR Scroll Wheel Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iHome iH8BR Scroll Wheel Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iHome iH8BR Scroll Wheel Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the back of the iHome is facing you, tilt the Motherboard Assembly upwards as shown.
    • Do not yank or jerk these ribbon cables. Make sure not to pull on the heads, but on the ribbons themselves.
    • Use tweezers to remove the 6 ribbon cables.
  9. iHome iH8BR Scroll Wheel Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the speakers, motherboard, and iPod adapter up and away from the lower casing.
    • You have now separated your iHome's inner workings from its protective case!
  10. iHome iH8BR Scroll Wheel Replacement, Scroll Wheel: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iHome iH8BR Scroll Wheel Replacement, Scroll Wheel: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iHome iH8BR Scroll Wheel Replacement, Scroll Wheel: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three 7.9 mm Phillips #1 screws holding the scroll wheel circuit board in place.
    • Repeat for the other circuit board.
  11. iHome iH8BR Scroll Wheel Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iHome iH8BR Scroll Wheel Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Firmly press on the center of each scroll wheel to remove them.
    • You have successfully removed the scroll wheels!
cfredric
crwdns2935283:004/17/13crwdne2935283:0
70 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-33, Amido Spring 2013 crwdns2935289:0Cal Poly, Team 12-33, Amido Spring 2013crwdne2935289:0
CPSU-AMIDO-S13S12G33
crwdns2947412:07crwdne2947412:0
where do you get the scroll wheels to replace the bad ones?
bnewell0568 - crwdns2934203:0crwdne2934203:0
Wow you can do the same thing leaving the entire unit intact by prying the wheels out from the top with a plastic pry tool. They come out pretty easily. This was still a very informative guide to disassembling the ihome.
huff08 - crwdns2934203:0crwdne2934203:0
I pried the scroll wheel off like said above, wiped off dust grime, replaced it - and now it works perfect.
Sgk Glass - crwdns2934203:0crwdne2934203:0
I ended up opening the whole thing up, taking the scroll wheels off and cleaning them. I also blew into the encoders on the little circuit boards, and it fixed them. They’re behaving just like new now. Thanks! I think I could have gotten away with prying the wheels off from the outside without opening it up, but oh well. This was actually on an iH6 — the innards were very similar to this model.
Doug Brown - crwdns2934203:0crwdne2934203:0
I did the same as Sgk Glass. Works fine.
mark b - crwdns2934203:0crwdne2934203:0
Popped off the vol wheel with plastic spud, cleaned wheel ans interior edges. Works like new.
Rick Murphy - crwdns2934203:0crwdne2934203:0
Thank you all for sharing above. I used a suction cup to lift the wheels from the top (so did not open the device), cleaned them -incuding the inner work- with a tissue and the result is great. Wheels are functioning as like i’ve bought the iHome iH8 yesterday.
gamename RR2 - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 4,240
