Remove any iPod or apple music device connected to the iHome and unplug from any power source.
Flip the iHome so the speakers are laying on a flat surface, and you have the concealed battery areas facing you.
Using your fingers, press down firmly on the plastic slide and push in the direction of the arrows shown above the word "Open" on the plastic.
Remove the plastic slide from its location and set it aside.
Remove all 4 AA batteries by placing your fingernail at one end of the battery and applying force upwards until the battery is freed from its holder.
Insert your fingernail or a prying tool under the notch of the plastic slide that is protecting the watch battery.
Set the plastic covering and the watch battery aside.
Remove the following screws:
Eight 10 mm using the Phillips #0 on the bottom of your device.
Use your fingers or a plastic opening tool to carefully pry apart the plastic connections still connecting the base to the top.
Slowly lift the plastic base towards you and lay it on the flat surface. The base should still be connected to the rest of the iHome by a few wires.
You should have visible access to most of the components inside the iHome now.
Two 10 mm Phillips #0
Pull out the AV circuit board and lift it up and out of the way to allow access to other components.
Pull the speakers away and set them aside for now. They should still be connected to the rest of the iHome by two wires.
Remove the following 6 screws:
Two 7 mm Phillips #0
Three 10 mm Phillips #2
One 9 mm Phillips #2
Carefully lift the main motherboard out of the way of the button control circuit board.
Four 6 mm Phillips head screws
Pull the button control motherboard up and out of the way.
Use a Flathead screwdriver to push on each of the button tabs.
Push the button away and out.
My volume decrease button was not working. I disassembled per these instructions, blew out the device with compressed air and then contact cleaner and reassembled per the reverse instructions. The screws in step 9 were slightly different (the same holes were there, but the presence/absence of screws was slightly different). I am now happily listening to my iHome right now. Thank you for posting this!!!
Brandy - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
