iHome iH27B AV circuit board Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. iHome iH27B AV circuit board Replacement, Outer Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove any iPod or apple music device connected to the iHome and unplug from any power source.
    • Flip the iHome so the speakers are laying on a flat surface, and you have the concealed battery areas facing you.
  2. iHome iH27B AV circuit board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iHome iH27B AV circuit board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iHome iH27B AV circuit board Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your fingers, press down firmly on the plastic slide and push in the direction of the arrows shown above the word "Open" on the plastic.
    • Remove the plastic slide from its location and set it aside.
    • These plastic slides are not interchangeable, so make sure each goes back to its original location in reassembly.
    • Remove all 4 AA batteries by placing your fingernail at one end of the battery and applying force upwards until the battery is freed from its holder.
    • Insert your fingernail or a prying tool under the notch of the plastic slide that is protecting the watch battery.
    • Set the plastic covering and the watch battery aside.
  3. iHome iH27B AV circuit board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following screws:
    • Eight 10 mm using the Phillips #0 on the bottom of your device.
    • Cataloging each screw by size in plastic bags or separate places on a flat surface will make them easier to find when reassembling.
  4. iHome iH27B AV circuit board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers or a plastic opening tool to carefully pry apart the plastic connections still connecting the base to the top.
    • Be careful not to pry too hard. Cracking the plastic connections could make reassembly harder.
  5. iHome iH27B AV circuit board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slowly lift the plastic base towards you and lay it on the flat surface. The base should still be connected to the rest of the iHome by a few wires.
    • You should have visible access to most of the components inside the iHome now.
  6. iHome iH27B AV circuit board Replacement, AV circuit board: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Two 10 mm Phillips #0
  7. iHome iH27B AV circuit board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the AV circuit board and lift it up and out of the way to allow access to other components.
John Kraemer
crwdns2935283:010/09/12crwdne2935283:0
76 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-21, Amido Fall 2012 crwdns2935289:0Cal Poly, Team 3-21, Amido Fall 2012crwdne2935289:0
CPSU-AMIDO-F12S3G21
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 212
