iHome iAVS16 LCD (Display) Replacement
    1. iHome iAVS16 LCD (Display) Replacement, Power Board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iHome iAVS16 LCD (Display) Replacement, Power Board: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iHome iAVS16 LCD (Display) Replacement, Power Board: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the four 1.7 mm Phillips #0 screws located on the bottom of the device.
      • Lift up the bottom of the device.
      • Carefully lift the bottom of the device up as to not damage the ribbon cable connecting it.
    2. iHome iAVS16 LCD (Display) Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iHome iAVS16 LCD (Display) Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iHome iAVS16 LCD (Display) Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the two 1.7 mm Phillips #0 screws holding the white face place onto the inside of the device's bottom.
      • Using an iFixit opening tool on the side without the black adhesive, carefully lift up the white face plate.
      • Lifting too quickly could damage the ribbon cable still attached.
    3. iHome iAVS16 LCD (Display) Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iHome iAVS16 LCD (Display) Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the tweezers, lift up on the black tab holding the ribbon cable down.
      • Carefully pull the ribbon cable back and out of the slot.
    4. iHome iAVS16 LCD (Display) Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iHome iAVS16 LCD (Display) Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iHome iAVS16 LCD (Display) Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the two 1.7 mm Phillips #0 screws holding the power board in.
      • Carefully flip the board over.
      • Remove the red connector from its socket with a pair of tweezers.
    1. iHome iAVS16 LCD (Display) Replacement, LCD (Display): crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iHome iAVS16 LCD (Display) Replacement, LCD (Display): crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iHome iAVS16 LCD (Display) Replacement, LCD (Display): crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert an iFixit opening tool into the lining on the front casing and pry it apart. Do this for both sides.
      • Further remove the front casing off from the device manually with your hands.
    2. iHome iAVS16 LCD (Display) Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four 1.7 mm Phillips #0 screws holding the LCD onto the front of the device.
    3. iHome iAVS16 LCD (Display) Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iHome iAVS16 LCD (Display) Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iHome iAVS16 LCD (Display) Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Carefully flip the LCD display over to expose the ribbon cable connecting it.
      • Lift the black tab holding the cable down, and carefully put it out of the socket.
Marco Sousa
crwdns2935283:010/25/19crwdne2935283:0
293 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G7, O'Connell Fall 2019 crwdns2935289:0UMass Dartmouth, Team S1-G7, O'Connell Fall 2019crwdne2935289:0
UMASSD-O'CONNELL-F19S1G7
crwdns2936753:030crwdne2936753:0 55
crwdns2942667:0crwdne2942667:0 503
