iHome IH11 Main Motherboard Replacement
  1. iHome IH11 Main Motherboard Replacement, Outer Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two 9.0 mm screws with a Phillips #1 screwdriver.
    • Remove the translucent bottom case.
  2. iHome IH11 Main Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iHome IH11 Main Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two Phillips #1 9.0mm screws on the back of the iHome.
    • Repeat the previous step for the two 9.0mm screws on the bottom.
    • Carefully slide the back cover off. There are wires connected to the back cover.
  3. iHome IH11 Main Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the aluminum bracket by loosening the two nuts and removing the 8.0 mm bolts.
    • Pull the bracket out.
  4. iHome IH11 Main Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iHome IH11 Main Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 12.0mm screws that hold the motherboard with a Phillips #1 screwdriver.
    • Slide the motherboard gently out.
  5. iHome IH11 Main Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Solder each wire to corresponding input on the motherboard.
Courtney Steinberg
crwdns2935283:004/19/13crwdne2935283:0
35 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 14-9, Maness Spring 2013 crwdns2935289:0Cal Poly, Team 14-9, Maness Spring 2013crwdne2935289:0
CPSU-MANESS-S13S14G9
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 412
