iHome IH11 Dock Connector Replacement
  1. iHome IH11 Dock Connector Replacement, Dock Connector: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 9mm screws that hold on the dock connector with a Phillips #1 Screwdriver.
  2. iHome IH11 Dock Connector Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iHome IH11 Dock Connector Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pop the dock connector out of the iHome and gently pull the white plastic plug connected to the dock connector apart.
    • Remove the four 7.0mm screws with a Phillips #1 screwdriver.
  3. iHome IH11 Dock Connector Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove both of the black plastic pieces. They should easily slide off of the two guide holes in the circuit board.
    • The dock connector should now be exposed. You can now simply put your new dock connector in the old one's place.
    Where can. I find the. Pin out. For this. Connector
    Roy H - crwdns2934203:0crwdne2934203:0
Nick Knowles
crwdns2935283:004/19/13crwdne2935283:0
21 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 14-9, Maness Spring 2013 crwdns2935289:0Cal Poly, Team 14-9, Maness Spring 2013crwdne2935289:0
CPSU-MANESS-S13S14G9
Where can I buy a replacement dock connector?
A Ross - crwdns2934203:0crwdne2934203:0
Likewise, this guide isn't much good if it uses parts that are unavailable.
CJ Shumate - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 2,434
