iHome IH11 AC Power Adapter Replacement
    1. iHome IH11 AC Power Adapter Replacement, Outer Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the two 9.0 mm screws with the Phillips #1.
      • Remove the translucent bottom plastic piece.
    2. iHome IH11 AC Power Adapter Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iHome IH11 AC Power Adapter Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the two 9.0mm screws on the back of the iHome with the Phillips #1 screwdriver.
      • Repeat the previous step for the two 9.0mm screws on the bottom.
      • Carefully slide the back cover off. There are wires attached to the back cover.
    3. iHome IH11 AC Power Adapter Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the aluminum bracket by loosening the two nuts and removing the 8.0mm bolts with your hand.
    4. iHome IH11 AC Power Adapter Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iHome IH11 AC Power Adapter Replacement, Motherboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the two 12.0mm screws that hold the motherboard with the Phillips #1 screwdriver.
      • Slide the motherboard gently out.
    5. iHome IH11 AC Power Adapter Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two 9.0 mm screws with the Phillips #1 screwdriver, then slide the circuit board for the AC adapter out.
      • Repeat the previous step by removing the two 9.0mm screws with the Phillips #1 screwdriver for the circuit board for the on/off switch.
    6. iHome IH11 AC Power Adapter Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iHome IH11 AC Power Adapter Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unsolder the main connections holding the AC adapter to the circuit board.
      • Solder new adapter in same position with same connections.
Nick Knowles
crwdns2935283:004/19/13crwdne2935283:0
21 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 14-9, Maness Spring 2013 crwdns2935289:0Cal Poly, Team 14-9, Maness Spring 2013crwdne2935289:0
CPSU-MANESS-S13S14G9
crwdns2942667:0crwdne2942667:0 1,042
