iHip Fold-Up Portable Speaker Stand Replacement
  1. iHip Fold-Up Portable Speaker Stand Replacement, Removing the battery case cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers to slide the battery case cover off in the direction of the arrows.
  2. iHip Fold-Up Portable Speaker Stand Replacement, Cleaning the battery case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iHip Fold-Up Portable Speaker Stand Replacement, Cleaning the battery case: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iHip Fold-Up Portable Speaker Stand Replacement, Cleaning the battery case: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four AAA batteries. Be sure to check your nearest battery recycling point!
    • Use the detailing brush and a paper towel to remove any corrosion left by previous batteries.
  3. iHip Fold-Up Portable Speaker Stand Replacement, Removing the screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iHip Fold-Up Portable Speaker Stand Replacement, Removing the screws: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver.
    • Screws will be magnetized in position and will require the use of tweezers to be removed.
    • Push down gently on the battery case cover and slide it in the direction the arrows indicate. Remove the batteries.
    • Unscrew the 0.6 mm screw located in the center of the battery case.
    • Keep the 1.0 mm and 0.6 mm screws separate from each other for reassembly.
  4. iHip Fold-Up Portable Speaker Stand Replacement, Removing the back cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iHip Fold-Up Portable Speaker Stand Replacement, Removing the back cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back cover carefully; there are many wires that connect it to the device.
  5. iHip Fold-Up Portable Speaker Stand Replacement, Positioning the Stand: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the stand backwards and around the system.
    • Make sure the stand is positioned perpendicular to the speaker system.
  6. iHip Fold-Up Portable Speaker Stand Replacement, Removing the Stand: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iHip Fold-Up Portable Speaker Stand Replacement, Removing the Stand: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the two small connection points for the stand.
    • Using small needle nose pliers, pinch the end of the stand toward the side of the speaker case.
    • Pop the end of the stand out of the hole in the side of the speaker case.
    • Repeat this step for the opposite side of the stand.
  7. iHip Fold-Up Portable Speaker Stand Replacement, Connecting The New Stand: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • 1. Position the new stand perpendicular to the speaker case.
    • 2. Align the bulbs at the end of the stand with the holes in the side of the speaker case.
    • 3. Gently push the bulbs into the holes of the speaker case.
    • 4. Pull the stand back around the speaker system.
Lisa
crwdns2935283:010/13/14crwdne2935283:0
207 crwdns2915208:0crwdne2915208:0
Clemson, Team 3-4, Benson Fall 2014 crwdns2935289:0Clemson, Team 3-4, Benson Fall 2014crwdne2935289:0
CLEM-BENSON-F14S3G4
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 278
