iDea USA CT702 Digitizer Glass Replacement
  1. iDea USA CT702 Digitizer Glass Replacement, Digitizer Glass: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place tablet on the table with screen facing upright.
    • Starting from the portholes, use plastic opening tool to pry in between the front panel and back cover.
    • Follow the opening along the corners and sides until all latches are unclipped.
    • Remove back cover completely and place it outside of the work area.
  2. iDea USA CT702 Digitizer Glass Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iDea USA CT702 Digitizer Glass Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place tablet facing down.
    • Locate the 4mm screws along the perimeter of the motherboard.
    • There should be 4 screws.
    • Use Philips screw driver to unscrew each one, and carefully place screws in a safe place.
  3. iDea USA CT702 Digitizer Glass Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iDea USA CT702 Digitizer Glass Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iDea USA CT702 Digitizer Glass Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After screws are removed, gently pull up on the ribbon wire connection to release all 3 wires from the motherboard.
    • Safely remove mother board and battery from tablet by using tweezers.
    • Make sure the small ribbon wires are not damaged when removing larger members.
  4. iDea USA CT702 Digitizer Glass Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove tape from battery pack, and dispose.
    • Be careful not to touch the wire/battery connection correctly, as it could result in injury.
  5. iDea USA CT702 Digitizer Glass Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iDea USA CT702 Digitizer Glass Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iDea USA CT702 Digitizer Glass Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After removing the battery pack and motherboard, the touch sensor unit should be visible.
    • Use small Philips screw driver to unscrew all 6 of the 2mm screws.
    • Use fingers and prying tool to remove the touch sensor unit from frame.
  6. iDea USA CT702 Digitizer Glass Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iDea USA CT702 Digitizer Glass Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iDea USA CT702 Digitizer Glass Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After the touch sensor is detached, only the plastic screen should remain.
    • Insert new touch sensor plate into the same position, aligning all screw inputs.
    • Insert all six of the 2mm. screws to connect the new touch sensor to the screen frame.
  7. iDea USA CT702 Digitizer Glass Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To continue reassembling the tablet, follow the steps in reverse.
    • Be careful when reconnecting battery, use safety goggles and gloves.
  8. iDea USA CT702 Digitizer Glass Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iDea USA CT702 Digitizer Glass Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iDea USA CT702 Digitizer Glass Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To reassemble tablet, follow these steps in reverse order.
David Kambich
crwdns2935283:003/11/15crwdne2935283:0
110 crwdns2915208:0crwdne2915208:0
Colorado Springs, Team 4-7, Panko Spring 2015 crwdns2935289:0Colorado Springs, Team 4-7, Panko Spring 2015crwdne2935289:0
UCCS-PANKO-S15S4G7
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 405
