iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement
  1. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  2. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery out of the computer.
  3. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement, Keyboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again. The locking screw is in between the F5 and F6 keys and is a clear piece of plastic.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
  4. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If the computer has an AirPort card installed, follow the next three steps to remove it.
    • Push the wire clasp away from the AirPort card and toward the display, then rotate up to free it from the RAM shield.
  5. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grasp the clear plastic tab on the AirPort card and pull toward the display.
  6. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold the AirPort card in one hand and use your other hand to remove the antenna cable.
  7. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four silver Phillips screws that secure the RAM shield.
  8. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
  9. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
    • Make sure that you reconnect the keyboard cable before replacing the RAM shield.
  10. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement, Lower Case: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a pin (or anything you like) to remove the three rubber feet from the lower case.
  11. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three newly-revealed Phillips screws.
  12. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
  13. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three hex screws using a T8 Torx screwdriver (or Allen screws using an Allen key if these are used).
    • The shorter screw is in the center of the computer.
  14. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two Phillips screws on either side of the battery contacts.
  15. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
    • Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
  16. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
    • Be careful not to break this clip!
  17. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
  18. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Continue to run the spudger around the front, right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound-out port.
  19. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are three tabs over the optical drive that must be released before the lower case can come off. Slide the spudger into the lower case above the optical drive and run it toward the back of the computer until you hear three distinct clicks.
  20. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the front and sides of the lower case are free, turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free (it may be helpful to jiggle the case up and down).
  21. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the small greasy springs with white plastic caps from either side of the battery contacts.
  22. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement, Bottom Shield: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following 10 screws from the bottom shield:
    • Six 3 mm Phillips
    • Three 7.5 mm Phillips
    • One 14 mm Phillips
  23. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the bottom shield off.
  24. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement, DC-In Board: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single Phillips screw securing the DC-In board.
  25. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the DC-In cable from the logic board.
  26. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Deroute the cable from around the optical drive, removing tape as necessary, and angle the DC-In board out of its compartment.
  27. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement, Upper Case: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following 11 screws from the bottom of the computer:
    • Three 3 mm Phillips around the battery compartment. (Some models may only have two screws.)
    • Three 4.5 mm Phillips along the optical drive bezel. (a magnetic screwdriver may help to lift these screws out)
    • One 11 mm Phillips in the lower right corner. (if present)
    • Four 14.5 mm Phillips.
  28. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • We recommend placing the computer on a soft cloth from this point on to prevent damaging the logic board.
    • Turn over the computer and open it.
    • Remove the 2 Phillips screws (3mm) from the edges of the keyboard area.
    • Remove the 4 mm Phillips screw from the lower left corner.
  29. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you can yank the upper case off, you must disconnect the trackpad connector, the blue and white power cable, and speaker cable as described in the next steps. Be especially careful with these cables; never pull directly on the cables, but use a spudger to pry up the connector directly.
    • Lift the upper case and use a spudger or your finger to disconnect the trackpad connector hidden beneath the white plastic tab. Due to model variatons your trackpad connector may be different than the one pictured.
  30. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the upper case about half of an inch and move it so that you can access the power and speaker cables.
  31. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The connectors at the ends of the cables are attached very firmly to the sockets on the logic board. Pulling directly on the cable will either separate the cable from its connector or the socket from the logic board.
    • Lift the upper case enough to disconnect the blue and white power cable from the logic board. Using your fingernails or a dental pick, carefully pry the connector from its socket. Make sure you're pulling only on the connector and not on the socket.
  32. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully disconnect the multicolored speaker cable from the logic board. As before, make sure you're pulling only on the connector and not on the socket.
  33. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement, Sleep Light: crwdns2935265:033crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single Phillips screw securing the sleep light to the metal framework.
  34. iBook G4 14" 933 MHz-1.33 GHz Sleep Light Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the computer over and disconnect the sleep light from the logic board, removing tape as necessary.
crwdns2935103:0crwdne2935103:0
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0636crwdne2935297:0
crwdns2942667:0crwdne2942667:0 3,098
