iBook G4 12" 800 MHz-1.2 GHz LCD Cover Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. iBook G4 12" 800 MHz-1.2 GHz LCD Cover Replacement, LCD Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the large piece of tape near the lower right corner of the display.
  2. iBook G4 12" 800 MHz-1.2 GHz LCD Cover Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iBook G4 12" 800 MHz-1.2 GHz LCD Cover Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the single screw inserted through the piece of EMI tape near the bottom edge of the display (it's the first of the two clutch cover screws).
    • Use the tip of a spudger to remove the small washer under the screw you just removed.
  3. iBook G4 12" 800 MHz-1.2 GHz LCD Cover Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel the aluminum/EMI tape as one piece off the cast aluminum frame of the clutch hinges.
    • It is not necessary to peel the tape off the thin steel LCD cover.
  4. iBook G4 12" 800 MHz-1.2 GHz LCD Cover Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the pieces of readily removable tape from around the perimeter of the display.
  5. iBook G4 12" 800 MHz-1.2 GHz LCD Cover Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iBook G4 12" 800 MHz-1.2 GHz LCD Cover Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the piece of aluminum tape near the center of the LCD cover.
    • Peel back the piece of tape securing the display data cable ground loop to the thin steel LCD cover.
  6. iBook G4 12" 800 MHz-1.2 GHz LCD Cover Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iBook G4 12" 800 MHz-1.2 GHz LCD Cover Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two Phillips screws securing each side of the LCD to the clutch hinge frame (four screws total).
  7. iBook G4 12" 800 MHz-1.2 GHz LCD Cover Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the thin steel LCD cover off the LCD.
crwdns2942667:0crwdne2942667:0 564
