Replacing the bezel covering the Lcd
Use a coin to unscrew the battery cover, and remove battery.
Use a t8 Torx driver to unscrew the two screws holding in the back cover, then remove the cover.
Open the screen, and remove the two t8 Torx screws holding the bezel in place.
Use a flat tip screw driver to unsnap the bezel from its place.
When at the top rubberized area, pry the bezel down.
