This motherboard includes all ports except the DC-In board.
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Push the wire clasp toward the Airport card and pull it up to free it from the RAM shield.
Grasp the clear plastic tab on the Airport card and pull toward the right.
Hold the Airport card in one hand and use your other hand to remove the antenna cable.
Remove the two 2.5 mm Phillips screws that secure the RAM shield.
Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
Note: The cable may have adhesive holding it to a shield. Pull in an upward direction gently, with an evenly distributed force across the cable until it comes loose from the shield.
I feel this step needs clarification: Are just lifting the cable away from the shield, or are we removing the cable entirely?
Your laptop should look approximately like this.
Don’t we need to remove the screws before the next step?
Remove the two long screws along the back edge, and the shorter screw in the middle. Torx T-8. Pry up the rubber feet, and unscrew the three Phillips screws that hold the feet in place. Putting the silver collars back requires a little bit of fiddling to get them oriented correctly so they sit flush with the bottom case.
Step 10 should come after step 15.
Use a pin (or anything you like) to remove the three rubber feet from the lower case.
Remove the three 5.2 mm newly-revealed Phillips screws.
Screw sizes are 2.5mm x 6mm flat low profile head or cheese head.
this should be after step 12 no?
This should be step 3.
Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
Remove the one 10 mm and two 20 mm hex screws using a 2mm hex. Alternatively, a T8 Torx screwdriver key will do.
FYI, the two screws at the top of this picture are longer than the one in the middle of the case. Don't mix them up!
Top screws are 20 mm, middle one is 10 mm. These have thread lock.
The 3 long screws (not the ones under the rubber feet) are 2.5mm x 20mm metric. Head style is cheese head. i found replacements for these at ACE hardware, for about $0.08 each in a flat head drive style which IMO are better than the hex style that can easily be stripped.
I'm using a T9 here as my T8 is way too small.
Two of the hex screws here got stripped. Please, replace them ASAP and I would recommend not putting them back just to not risk making them stuck. I spent 30 minutes trying to get those two out.
Remove the two 4.2 mm Phillips screws on either side of the battery contacts.
Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
If your iBook's been opened many times (Like mine has been) then this piece may be broken.
If it's cracked down the middle or a little off, what you'll want to do is use your bent paperclip from a few steps later (or another screwdriver) and pull the second piece away from the shell when you start lifting. should pull right out
Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
Continue to run the spudger around the front, right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound out port.
isn’t this step out of order? It belongs much later I think
This should be step 4.
Once the front and sides of the lower case are free, turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free (it may be helpful to jiggle the case up and down).
You might wanna use your spudger to pry up those back tabs to. You might break the bottom case just wiggling around waiting for it to pop loose.
The orange screw on my machine has no head on it and is simply a flat surface. There is no way to remove it and consequently I completely trashed my unit attempting to remove the top cover.
There went a few bucks all for nothing as I had a spare HD sitting here ready to put in!
Be aware that you may need to use a spudger at the front of the computer to separate the metal shield from the bottom case.
Remove the small greasy springs with white plastic caps from either side of the battery contacts.
Clean the springs and put them back, hopefully without breaking the small plastic pieces on the top of each spring. One of mine broke off and the other one was already missing. Poor design.
Remove the five 5.8 mm Phillips screws from the bottom shield.
Peel back the yellow tape and foil shielding outlined in the image.
Upper left screw is 4.5 mm and has smaller head. The other four are 6 mm.
Don't peel back the long foil shielding pictured top right! It should stay attached to the bottom shield that you are removing.
crwdns2936937:0commentercrwdne2936937:0
All of the five screws are the same 6 mm in length (iBook G3 600 MHz)
Remove the following 4 screws on the bottom of the computer:
Two 3 mm Phillips from the left side of the computer.
One 4.5 mm Phillips near the latch mechanism (this screw may be missing in 800 MHz iBooks)
One 14.2 mm Phillips near the front, right corner.
This photo is a little confusing. The shield should be off, which would show the correct positions of the yellow and orange screws. (The orange circle is in the wrong place.) Furthermore, these screws don't need to be removed at this stage (they hold the logic board to the frame). And finally, on my 800 MHz machine, BOTH these screws are 6 mm in length.
The two red screws and the orange screw have to be removed (iBook G3 600 MHz).
crwdns2936937:0Rolf Hugcrwdne2936937:0
As well the yellow screw has to be removed according to description
On my 800, the yellow screw is a 6mm Phillips with a wide head.
Use a straightened paperclip to open the optical drive tray.
Pull the optical drive out just enough so that you can access and remove a Phillips screw near the battery compartment.
this is the most difficult part in the whole repair
i think that we can leave that one out on re-assembly
It's quite hard to get to the screw and loosen it.
If you fully extend the tray it's fairly easy to get to the screw by going inside the rails. And grab it with tweezers.
When re-installing use something sticky on your screwdriver to hold the screw in place, or it's never going in. The sleep magnet is nasty at grabbing your screw and pulling it away. (Doesn't hurt to have something sticky on it for taking it out too...)
There is no way to go in STRAIGHT without risking to damage the tray! The screw head is just too far off to the left and is covered by the tray. So I opened completely the tray and I could barely remove it from inside the try guide.
Hey Steve; My advice would be to NEVER replace a tray drive with a slot drive! In my-not-very-humble opinion, slot drives are garbage, and are unfit to be used in ANY Mac computer.
If you're doing this type of work, what's wonderful is to have a set of technicians magnetic drivers. I have a set of twelve that are about 6"long, and very skinny. Phillips 1, 0, 00, & 000 . . . Torx 6, 7, 8, 9, & 10 . . . and slotted 5/64", 3/32", & 1/8". I wish I could remember where I got them, but you could probably Google it. One of the smaller magnetic Phillips was perfect for removal AND replacing this screw. A word of CAUTION, though . . . probably best to keep any magnetic tools away from sensitive components on the PC board.
To anyone that’s absolutely stuck: there is a little slot along the drive where the screwdriver fits in. I didn’t know this for at least 3 times I took apart this computer, and finding this now has helped me sooooo much.
Pull the optical drive a bit more so that you can access and remove a second Phillips screw near the power receptacle.
This one is tiniest (shortist) so far
Be sure when installing a slot drive to replace these screws before installing the drive!!
Turn over the computer and open it.
Use tweezers (or a refrigerator magnet) to remove the magnet covering a Phillips screw near the middle of the computer.
Forget the tweezers or magnet. Just use a 1.0 common tip/flat blade screw driver and flip the magnet out of its receptacle. Takes just a few seconds to do.
Remove the following 4 screws on the edges of the keyboard area.
One 4.5 mm Phillips underneath where the magnet was.
Three 6 mm Phillips in plastic depressions.
the three 6mm screws may require more torque than previous screws.
Peel up the foil tape covering the speaker cable near the ports.
1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
2) After disengaging the locking bar, slide the cable out of the connector.
Loosen the trackpad connector by pulling the top piece up slightly, freeing the trackpad ribbon.
Slide the orange trackpad ribbon out of the connector.
Lift the upper case from the left side and use your other hand to pull out the right side in order to clear the power receptacle.
I had one (800MHz), that on the B&W power cable, it was so tight that it pulled the socket from the PC board. Never had that happen before, although the potential exists on many of them. Needless to say, that machine is now allocated as a parts unit. What I found is the safest way, and really not all that much trouble, is the remove the 5 screws, peel back the tape, and remove the speaker/switch units from the top cover. Worked for me, and avoided the risk mentioned above.
Lift the upper case enough to disconnect the blue and white power cable from the logic board. Using your fingernails or a dental pick, carefully pry the connector from its socket. Make sure you're pulling only on the connector and not on the socket.
blue up and white down
Not unless you have to! Most parts can be removed with this left in. Don't try pulling on it unless you have to, it can easily break the logic board. Just tilt the upper case up to lean it on the display.
Much easier if you do this after Step 37.
when putting back the connectors I bent the bloody pins, do it when you are relaxed............
crwdns2936937:0bgfracrwdne2936937:0
Can easily repair them using a watch repair magnifier (3 euros)
It is alot easier to get at after you pull the speaker cable out. Use something small to pop it out of place though, I broke my extra spare being a little too hasty.
This connector has a small catch on the right. slipping a sharp object (eg: pin) between the connector and it holder will release the catch. The connector should now come off easily.
I put this comment in the last step, but perhaps it should go here as well:
Lift the upper case off completely and disconnect the red and black speaker cable from the logic board. As before, make sure you're pulling only on the connector and not on the socket.
There is a magnet covering a screw to the left of the serial number located in the upper center of the upper case. Remove the magnet, smooth,round and small, and loosen (doesn't need to come out) the screw to remove the upper case. Proceed to disconnecting the speaker and power cables. NOTE: this magnet is not the same one indicated in step image 33.
Oops - second attempt to install a hard drive in this; the second time unlucky. Last time I left the red and black cable in place; this time, I ripped the socket mentioned out.
The DC board can be removed now. Disconnect the cable from the DC board. There is enough play to lift the board out. There is no need to remove the top shield.
I found that at this point I was able to avoid any further steps by removing the screw from the DC in board and the flip the machine over to reveal its connection to the board. I removed this connection and then was able to wiggle the board out and snake the cord out. Avoiding Step 38 saves a lot of screw removal. Not to mention not having to remove the CD Drive also saves a lot of time.
Just be careful when doing this that you do not force the board out of its place. There is room to remove it, but it is a gentle task.
Remove the following 14 screws (some models may be missing a couple of screws):
One 2.5 mm Phillips.
Six 3.5 mm Phillips.
One 4.5 mm Phillips near the sleep light with a small shaft.
Two 4.5 mm Phillips with larger shafts.
Four 5 mm Phillips
If a screw is inserted in the left hole, the 14.2 mm screw in step 24 can not be inserted to hold the top case down.
If your iBook is like mine (700MHz) The yellow screw was attached from the bottom through the bottom case and had to be removed earlier in order to remove the bottom case. Also the the green screw pictured to the left was missing already removed.
crwdns2936937:0neatocrwdne2936937:0
It's the same to iBook G3 600 MHz
It is also the same for the iBook G3 500 MHz (late 2001)!
Peel back three strips of yellow tape in the bottom left corner.
Peel back one strip of foil tape in the upper left corner and another near where the trackpad connects to the logic board.
The foil tape next to the trackpad connector is not marked in the pic
There is also foil tape, cetre front, in the cutout for the catch mechanism
Lift the top shield up from the right side, minding the upper left corner, which may catch on the metal framework.
Remove the single strip of tape running across the modem.
Remove the single Phillips securing the display data cable to the metal framework.
Move the display data cable to the right in order to access and remove a single Phillips screw.
Remove the single Phillips screw remaining at the upper, right corner of the modem.
Lift the modem from the logic board on the right side, being careful not to strain the display data cable.
Disconnect the modem cable from the left side of the modem.
Slide the modem out of the computer, being careful to avoid catching the black plastic shielding on the surrounding cables.
Use the transparent orange loop to disconnect the large orange ribbon cable from the logic board.
Lift up the front edge of the hard drive.
Peel back the black tape to free the microphone cable from the hard drive.
This is hidden under the HD. Be careful when removing, just grasp the top edge. Remember the way it is seated, or it is impossible to connect.
Use the transparent orange loop to disconnect the hard drive ribbon cable from the hard drive.
Disconnect the microphone cable from the front, left corner of the logic board.
Peel back the black tape and free the microphone cable from the hard drive.
Use the black plastic handle to disconnect the display data cable from the logic board.
Deroute the display data and microphone cables.
ended up leaving the display cable routed, had a piece of steel framing i could not get it around without the risk of tearing the cable.
Peel back the yellow tape securing the inverter cable to the optical drive.
Disconnect the inverter cable from the logic board.
Carefully deroute the inverter cable from beneath the optical drive.
Deroute the Airport antenna cable from beneath the optical drive.
Remove the single Phillips screw on the outer edge of either hinge (two screws total).
Tilt the display back to get over two small nubbins, and then slide it directly from the case and away.
On the bottom of the computer, disconnect the DC-In cable from the logic board.
No reason to disconnect the DC-In cable. Nothing we are doing requires it disconnected and it is a fragile and vital piece of a "working machine."
Flip the computer over and open the display.
Open the optical drive using a straightened paperclip (if it's not already opened).
Peel up the yellow tape from the optical drive.
Remove the two Phillips screws securing the optical drive to the metal framework.
Peel back the orange ribbon cable to reveal a single Phillips screw. Remove this screw to free the optical drive from the metal framework.
In my iBook, there was no need to remove the screw under the ribbon cable. It's just a part of the optical drive.
On mine (800MHz) there are 2 screws visible here, one of which is, indeed, just one of the optical drive case screws as you mentioned. But the other one was what it appears is mentioned here in Step 44.
Lift the optical drive by the edge closest to the screen, minding that the metal bracket at the top left corner doesn't catch on the Airport or inverter cables.
Remove the two 2.5 mm Phillips screws securing the large orange ribbon cable and thin metal bracket to the drive.
Disconnect the ribbon cable from the optical drive.
If you've made it this far, you've probably realized that you underestimated the work involved. You can finish, but it's going to be painful.
Remove the three Phillips securing the heat sink to the metal framework.
Remove the rear plastic grill and IO Bezel.
Turn the remains of the computer over.
Remove the following 6 screws:
One 4 mm Phillips at the upper right corner of the logic board.
One 6 mm Phillips at the front of the computer, near the sleep light.
Two 6 mm small-head Philips from the middle of the logic board
Two 7.5 mm small-head Phillips, one on either side of the battery contacts.
If you have been following along, the 6 mm (orange) screw here would have already been removed in step 24, where its position is not quite correct, and it is incorrectly labeled as a "4.5 mm" screw.
Turn the remains of the computer over again.
Lift the heat sink out of the computer.
Disconnect the sleep light from the logic board.
Turn the remains of the computer over (for the last time).
Disconnect the fan cable from the logic board.
Press the metal framework out as shown and lift the logic board out of the computer, holding it near the battery contacts.
crwdns2935229:027crwdne2935229:0
crwdns2935103:0crwdne2935103:0
crwdns2917034:0crwdne2917034:0
Great instructions. I never took apart a computer before and I was able to complete the task and my ibook works great! Thank you! BTW- I am a woman and if I can do this so can others:-)
Patricia
Also unplug the computer just before taking the two steps described above.
Ken Horner - crwdns2934203:0crwdne2934203:0
