Use this guide if your track pad is damaged or unresponsive. Make sure you are wearing the Anti-Static Wrist Strap and remove the battery to avoid damaging the electronics.
crwdns2935267:0crwdne2935267:0Anti-Static Wrist Strap$7.95
Put on Anti Static Wrist Strap.
Flip Computer Upside down.
Unscrew the eight 3.3mm black screws on the back casing with the T4 Torx Screwdriver.
Use the plastic opening tool to lift the back case off.
Remove the six 2.0mm silver screws and the two 3.2 mm black screws using the PH00 Phillips Screw Head.
Gently unplug from CONO851 plug, using the plastic opening tool.
Gently lift up the battery and remove using the plastic opening tools.
Unscrew the five 2.3 mm screws using the PH000 screw head.
Lift up the latch using the nylon spudger.
